Anyone install a head unit...
Old Dec 21, 2000 | 02:52 PM
JeffesonM's Avatar
living out of a maxima...
...and know which color wires connects to right and left rear speakers?
Old Dec 21, 2000 | 02:53 PM
JeffesonM's Avatar
(wires that connect from car to headunit)
Old Dec 21, 2000 | 06:13 PM
ray89se's Avatar
u have an amp in the rear
if u got the active system if u got the bose u it is better to run new speaker wire to the head unit
Old Dec 21, 2000 | 07:46 PM
JeffesonM's Avatar
no, I've already replaced head unit, speakers, and cable as well as put in amps. I'm connecting a neon light in my trunk and I was going to use the stock wiring instead of running another wire from behind the head unit (switch nearby) to trunk for light. Just need to know which color wire connects to back right or left speaker.
Old Dec 21, 2000 | 07:48 PM
Foo90SE
I know its 2 of the group of wires with the grey rubber covers...ill look at my car tomorrow(all my wiring is exposed...long story ) if noone tells ya b4 then
Old Dec 21, 2000 | 08:56 PM
Matt93SE's Avatar
STFU n00b!
Yup.. just use any two wires in the grey cable. they all go to the rear stock amp, so they're not used now.. just make sure they're not connected to anything else (i.e. one wire isn't tied to ground anywhere.. sometimes automakers do that on certain types of stereos.)
if you had bose, then I'm not sure what kind of wires you'll have..
Old Dec 21, 2000 | 09:58 PM
Foo90SE
Yeah..just for clarification, i have the Bose so if u do have the bose, i can tell ya which 2 sets go to the back
Old Dec 22, 2000 | 07:05 AM
JeffesonM's Avatar
Yup, I had the old Bose system. By the way, Foo, did you ever get pics of your CAI setup?
Old Dec 22, 2000 | 08:19 AM
Foo90SE
I dropped off the film a few days ago but its been icy down here...should be there today
Old Dec 22, 2000 | 11:34 AM
Foo90SE
Ok...white/red stripe and black/red stripe is the rear right speaker, white/blue stripe and black/blue stripe is rear left
you do have to cut open the harness to the factory amp and get to the wires in the grey cover to utilize these..cant use the wires coming FROM the amp
Hope this helps
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
rnb754
Sep 14, 2015 11:39 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
