problem with amp install w/ bose
Old Oct 5, 2002 | 08:52 PM
MaXtUneD's Avatar
I installed everything correctly except the remote wire.heres the problem...I hooked the remote wire to one of the rear speakers.When I turn the stereo on, the amp light turns on but slowy fades off...What could be wrong???
Old Oct 6, 2002 | 01:11 PM
PATRICK94SE's Avatar
Is it hooked up to the speaker input (small wire) or the amp power (big wire)
Old Oct 6, 2002 | 01:32 PM
MaXtUneD's Avatar
how do i hook up the remote wire without bringing the wire all the way to the head unit???
Old Oct 7, 2002 | 09:39 AM
aeubank's Avatar
The best thing to do is run the remote startup wire from the new head unit. I've redone the radio in my '92 SE twice. both times I wanted to add additional power. Now she screams!!. Here's some of the things I did with the factory system:
First, remove the back speakers and place them under your dog's house. That's all their good for.
Next, run your own speaker wires to the back speakers. I tried using the factory harness but decided it wasn't worth the hassle of going around those cheesy amps (on the SE). This solves the problems for the rear speakers.
Next, I defeated the amplifier in the front Bose speakers. At first I took the speakers out and saved them. Then 7 yers later I realized that these were REAL Bose speakers. I unhooked the amplifier by opening the enclosure and placing a standard wire on it and running the lead through the bass port. Kind of goofy looking but works like a charm, and beats any other speakers you may try like 6 1/2s.
Next, hooked up the speakers with the car wiring. Didn't feel like running through the tunnel in the door.
Finallly, remove the factory radio. I gave mine away to my uncle who couldn't use it in his GXE model.
After I completed all of the steps listed above, added additional amps, 4 ga battery wire, and power amps mounted on a board, all ran fine..
Happy hunting..
Lakersallday24
Nov 7, 2024 07:31 PM
melteye
May 16, 2016 12:02 AM
homeyclaus
Sep 3, 2015 06:15 PM
Maxinesdaddy
Aug 21, 2015 11:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
