HAS ANYONE REPLACED A 5-SPD in92se??
Old Oct 10, 2002 | 08:24 AM
LP92se's Avatar
I have a 92 Maxima SE w/ limited slip 5-spd transmission... I am picking up a used tranny and replacing it soon,... I have never done any kind of tranny work ever.. Can anyone give me some pointers or tips about the best way to do this and what other things i'll need or should replace at the same time?
Thanks,
-Lance
Old Oct 10, 2002 | 08:31 AM
male's Avatar
Replace clutch, resurface flywheel, lube the release bearing well. I stress this. Have a helper to remove and position it for reinsallation. If you aren't going inside the trans, this should be it. Oh, and spend extra time cleaning the clutch housing on the trans. Super clean is best. If you can go the input shaft seal too that would be good. Good luck
Old Oct 10, 2002 | 08:33 AM
Laly's Avatar
actually my tranny just went bad the other day and is at my uncles shop right now. we are also looking to get a used tranny. do all SE's 5 speeds come with LSD?
Old Oct 10, 2002 | 09:01 AM
LP92se's Avatar
Im not sure but when I called about A used one for my year and model they still asked if it was LSD
Old Oct 10, 2002 | 09:30 AM
92vemaxse's Avatar
I'm just wondering what you paid for that LSD transmission. I replaced my LSD 5-speed about a year ago and I paid about $700 shipped. It took me over 2 weeks to find an LSD trans! Also, make sure that you use the right gear lube for the trans. I believe that our cars that GL-3 or GL-4...someone else know for sure??
Old Oct 10, 2002 | 10:21 AM
Matt93SE's Avatar
STFU n00b!
you can get them w/ or w/o LSD.
you can't change the input shaft seal. you'd have to crack the case open to do that. be sure to replace the rear main seal on the engine and both axle seals though. also replace the shifter linkage seal and the boot on it. lube your shifter linkage bushings too.
read my directions here:
http://www.ee.utulsa.edu/~mblehm/faq...eplacement.txt
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
