lights any idea's
Old Nov 4, 2002 | 09:50 PM
VE30DEPOWER's Avatar
lights any idea's
just want to see if anyone has some ideas my "pass' side headlight went out so i check it turns out i got the melted plug symptom so while i was at it i looked at the driver side and it was starting to melt so i bought 2 9004 plugs got 2 stock wattage bulb hooked them up all wires are correct etc,turn on light only driver side works "this is with the 2 new bulbs in" on low beam,so i pull the lever for high beam and both work.. so i go thru the normal steps check relays,fuses,etc..all is good. anybody have any ideas on what else it can be "like make sure the cigarette lighter fuse is not blown hehehe " some cars are like that.. my next step tommorrow is to take the headlight switch lever out and see if thats bad..
Old Nov 4, 2002 | 09:54 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
humor me and swap the left bulb into the right and vice versa and see what you come up with
Old Nov 4, 2002 | 10:14 PM
did that also and same thing D/S worked and the PASS didnt..
Old Nov 4, 2002 | 10:19 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i had this problem when i redid my sockets and it turned out to be a bad ground wire
Old Nov 5, 2002 | 02:52 PM
MyMax92's Avatar
Re: lights any idea's
Hey, i was wondering that, my cig. lighter fuse is blown, replaced the fuse and it blew again and again, wats up w/ that?, itz only the cig lighter so it hasnt really mattered, but i want to use my car charger for my cell phone if i go on a trip...any idea's?
Old Nov 5, 2002 | 03:10 PM
latinmaxima's Avatar
you will have to replace the plug because where it melted, the power wire will no longer sit in the right spot to make contact with the bulb. i recommend getting an upgraded harness for your headlights if you realy want to run higher wattage bulbs.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
