1992 Maxima SE dumping fuel
Hello all.... thought replacing my MAF sensor would fix my problem... but nope still screwed up.... whats happening is car runs (rough) and is dumping raw fuel into the exhaust and spitting out tail pipe! its all gas (what a head rush) I've replaced about everything Injectors, coils, fuel filter, plugs MAF sensor... what else can it Be?????? GOING NUTZ HERE!!!!!!!!
Re: hey man!
Originally posted by dnas420
i figure ill give you my 2cents. I think possibly those missing vacuum hoses were part of the problem. I'm still baffled...
Re: Re: hey man!
Originally posted by male
injectors are brand new... i will check regulator today (fingers crossed)
Check the vac lint that goes to the FPR..if there's gas in the line..FPR is shot..but it might be bad even if there isn't..but it's a quick check. And you must know that our cars are notorious for fuel injector probs, so you might have some leakers. After you figure it out, your cat might eat it pretty soon, they don't take too well to raw fuel.
Re: Re: Re: hey man!
Originally posted by 2manycars
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Your computer could also be the culprit. The FSM gives some troubleshooting when dealing with the fuel injection system. The computer could be screwing up so that its not controlling the injectors and they are running all the time.
Originally posted by eric93SE Where is computer located?? how do i test it? I have no check engine light on (never have)? Thanx
Hard finding a Chilton with reference to the DOHC motor they all are based on the SOHC that I've found?
If I were you, get Chilton. It gives you all the info on how to do a self diagnostic using the ECU. Might have to read it a few times to get it, but it's pretty good. I have had a Chilton for every vehicle I've owned. At the least you will undrstand what the mechanic is telling you, and help you figure out if you are getting taken. You still should do all the things we discussed earlier.
ITS YOUR O2 sensor!!!
look for the 4th engine mount, behind the engine itself. there sould be a connection that is mounted to the mount. thats the O2 sensor dissconect that sucker and see if your car runs better. if soo then its your O2 sensor thats bad.... the car wont feel 100% better when you unplug it but you will beable to tell if the problem is still there.... i had the same prob.. i spent about 100 bucks before i got a new O2 senosr...
Originally posted by 92vemaxse
Did you put oil on the o-rings of the injectors? They break easily and could be dumping fuel.
Brian
Brian
If the injectors 0-rings are fubar'd on install, it will allow fuel to leak PAST AND AROUND the injector itself. I think it maybe a injector or o-ring like the above person mentioned.
I just pulled all 6 splugs and the back 2 were wet with fuel... I cranked over motor with all plugs out and the back 2 clyinder sprayed fuel out like crazy the other 4 were fine.....?????? is this 2 bad injectors?
kjlouis
11-24-2018 06:09 AM
