Pathfinder intake
Pathfinder intake
I think this is the intake plenum the 510 guys said was the best flowing ones. the look good too http://cgi.ebay.com/ebaymotors/ws/eB...tem=1871829576
Re: Pathfinder intake
Originally posted by Chris91SE
i still don't see how the TB etc will bolt on to that...looks like you'd still need more pathfinder parts to get that to work...
that 520 site said the pathfinder intake flows 30% better than any other vg30 intake so i'm sure it would be good, it would just be a pain to get in probably. Also, talk to Egnloid about extrude hone, he has a really good point about it not being the best way to make air flow better.
I say stick with the 3rd gen IM. Looking at the pathfinder VG30 it makes 153hp/182tq, while the max does 160hp/182tq. However the pathfinder peaks around 4000rpm but the max peaks at 2800rpm. The max IM should have more torque from 2500-6000rpm over the pathfinder setup. Since the cams are the same specs the only difference in power is from the IM.
mtcookson,
I know Engloids theory on extrudehone, but it is alot easier than sectioning your manifold, hand porting it, and TIG welding it back together. Also, I'm not sure that Extrudehone actually behaves the way Engloid describes, I mean, it is under pressure not just flowing freely through the passage. Also,the way to get better airflow through a passage is to straighten the passage as much as possible, right, because air doesn't like to make turns. So the putty is being pressed throught the passage, it reaches a bend and what does it do? It wants to go straight, pushing against the outside of the bend, removing more material forom the outside of the bend, thereby straightening the path. Sound logical? I know, Engloid's idea sounds logical too, but the only way to really find out is to try hand porting Vs. Extrude Hone and flowtesting it.
Yes the VG33 makes 170hp, but the VG30 from 88-96 make 153hp/180tq. Therefore the 3rd gen IM is the better one.
Originally posted by male
Pretty sure the cams are different. and I was sure the vg33 makes 170 hp, but regardless,
Originally posted by surfermax92
BTW, does anyone know whether the vg33e heads flow better than our max heads?
Granted, I will admit that I think ExtrudeHone would so better on this pathfinder intake than it would on the maxima and Z intake just because it has 2 primary runners that branch off (sharp curves) that would not do as well with this process.
Originally posted by Engloid
Yeah...but make the ports straight, and they will not only go through the intake walls, making holes, but it will not get air to your cylinders. It's erosion...just look how straight the ohio river is..haha
I meant straighter, not straight. WOuldn't work too well with holes in the intake walls!
if you have a port traveling to the right..and curving downward... then you erode it internally like the extrude hone process does..
it will take more material from the point near tangent to the straight part, and on the outer radius. As this point erodes more and more, it will begin to make a dished area there, creating turbulence and worse flow.
what do you guys think about sand blasting the inside? has lots of air going through like an intake would do but you also have sand to kind of clean it up and stuff.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
maxima297
Sep 30, 2015 03:32 PM
