Is it possible to use a different model knock sensor?
As you know, the 92se-ve30de knock sensor is buried under the intake manifold. Would it be possible to substitute a different sensor like this one from a 300zx 90-95 which mounts right under the plenum.
No but I need to. I just had to spend $400 getting 3 $1 freeze plugs replaced on the back of the motor, between the block and transmission. Trans had to be pulled. It's gonna cost that much to get the KS replced. I was just thinking, since all it does it detect knocking/pinging, I should be able to use the one that mounts in an easier place.
Originally posted by Aaron92SE
Have you replaced you KS yet?
Originally posted by RosenKen
I have it in hand but I forgot to order the sub-harness for it (might as well replace that since they seem to corrode). Upon receipt of that, I will replace it as soon as I get a few free hours. Maybe next weekend.
So, you're saying that i only takes a few hours to replace this part? If this is the case, I need to change mine. I have a mechanice friend that will be able to help me through the process along with a FSM. I'd figure this is a process that you will have parts all over the place and will take a couple days.
ballerchris510
Sep 23, 2015 08:46 PM
JoshG
51
Sep 21, 2015 10:41 PM
