My car starts up strangly, and BMW lights
Old Nov 11, 2002 | 11:25 AM
OoTOAoO's Avatar
I own a 1991 Maxima and I've had problems starting it for about the past 6 months. I had the distributor cap changed (along with the thing that spins in the middle, i forget what thats called). It will always start (eventually), but sometimes I have to leave the key turned and I sit there and hear the car trying to start for sometimes as long as about 15 seconds. Other times it starts fine. It seems like it's worse when the weather is colder. Also, does anyone know which BMW headlights work for the 91 Maxima? Any response would be great, thanks.
Old Nov 11, 2002 | 02:54 PM
max95q's Avatar
Re: My car starts up strangly, and BMW lights
Bmw lights: its the E36 headlights
Old Nov 11, 2002 | 02:55 PM
nismo-max500's Avatar
i wouldnt recommend turnin the key for 15 sec
Old Nov 11, 2002 | 08:42 PM
OoTOAoO's Avatar
Re: i wouldnt recommend turnin the key for 15 sec
Originally posted by nismo-max500
Do you know what I could do to fix it or what it might be?
Old Nov 11, 2002 | 08:46 PM
mtcookson's Avatar
does it seem to run normal once started up?
Old Nov 11, 2002 | 11:01 PM
OoTOAoO's Avatar
Yes, perfectly fine.
Old Nov 12, 2002 | 01:56 PM
mtcookson's Avatar
haynes says when hard to start cold it could be
1. Battery dsicharged or low
2. Malfunctioning fuel system
3. Faulty cold start injector
4. Injector(s) leaking
5. Crank angle sensor rotor carbon tacked
Old Nov 12, 2002 | 02:04 PM
VisualEvolution's Avatar
Have you checked your starter. I know i ran into a problem like that sort of. I checked my starter and I had to get the wires replaced cause they where old ever since that starts up fine. Or try tapping on the starter I dont know just trying to help ya out.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
Gsantos79
Aug 8, 2015 07:41 AM
