VE 5-spd different from VG 5-spd?
Old Nov 17, 2002 | 08:44 AM
Sawby4president's Avatar
I used to have a '91 SE 5-spd VG, and I recently unloaded it and picked up a '94 SE 5-spd. I've noticed that the shifter feels different, and that reverse isn't nearly as loud. Overall the unit mated to the VE feels much more solid. Did Nissan put a different manual trans on '92-'94 SE models?
Old Nov 17, 2002 | 08:46 AM
SEguy182's Avatar
Re: VE 5-spd different from VG 5-spd?
different motor and different transmission for the new motor
Old Nov 17, 2002 | 08:54 AM
dnas420's Avatar
yeah
they upgraded from mice to rats on the excersize wheel!
Old Nov 17, 2002 | 08:57 AM
lophix's Avatar
Re: yeah
Old Nov 17, 2002 | 09:48 AM
92vemaxse's Avatar
Also, you may, just may, be lucky enough to have a LSD tranny in your max. Two easy ways to tell: Rev the car to about 4 grand and let the clutch out, two marks = LSD trans, or post the tranny code from the metal plate under the hood on the center of the firewall. I have the LSD trans in my car so I can compare the codes.
Brian
Old Nov 17, 2002 | 12:12 PM
«§»Craig B«§»'s Avatar
Re: Re: VE 5-spd different from VG 5-spd?
Brian
the tranny with LSD ends in a "V", the others do not
Old Nov 17, 2002 | 01:16 PM
nubiannupe's Avatar
OG Maxima.org Member
Re: Re: Re: VE 5-spd different from VG 5-spd?
In other words, Craig, you're telling him to save the clutch and check the codes???
Old Nov 17, 2002 | 01:29 PM
Re: Re: Re: Re: VE 5-spd different from VG 5-spd?
yeah, pretty much
probably a better idea just to check that code
Old Nov 17, 2002 | 03:34 PM
Brian
My tranny code: RS505FV FG38 (another code I think). According to craig B the "V" ending would denote a limited slip diff., but let me know if your car has the same code.
Old Nov 17, 2002 | 03:39 PM
another question
while people are actually answering my post (it doesn't seem to happen often, maybe I ask too many questions), how does one replace the 02 sensor on a VE? Are OEM nissan parts recommended, or would a Bosch or something else be okay? My car is about half as fast when it's warmed up as when cold, regardless of outside temperature. Runs rough but strong when cold, smooth but weak when warmed.
Old Nov 17, 2002 | 04:01 PM
RosenKen's Avatar
Yup, you got LSD. Good job
Old Nov 17, 2002 | 06:28 PM
jwtarbaj's Avatar
Brian
According to my sources ALL US spec Maxima SE's from 92-94 have the LSD if they are 5-speed manual. The beefed up trans for the VE also added LSD to eliminate torque steer. There are no VE manuals that have non-LSD trannies.
Old Nov 17, 2002 | 06:33 PM
RosenKen's Avatar
Well, there's still torque steer in my car. LSD won't make that disappear. But for a high-powered front driver the Max isn't that bad on torque steer. I only feel it while planting it in a turn in a low gear (1st or 2nd). Or maybe it's just that I'm used to it now.
Old Nov 17, 2002 | 06:51 PM
jwtarbaj's Avatar
I agree totally. That is the reason they put it in and it does HELP but it will still happen. I had a 93 SE-R which ALL original Sentra SE-Rs (91-94) came with LSD (same basic system as in 92-94 SEs). It used to switch when accelerating in a straight line and tug left-right-left-right. It was kind of interesting to watch. It is not a perfect system considering that it is mechanical and based on fluid coupling heating up.
Old Nov 18, 2002 | 06:00 AM
ThurzNite's Avatar
If I get a short throw shifter for a VE, will it fit a VG?
Jae
Old Nov 18, 2002 | 06:31 AM
Jae
yes, the shifter mechanisms are the same
Old Nov 18, 2002 | 07:43 AM
subs1000w's Avatar
i have a 92 5 speed and if i jack the front end up and turn one of the tires forward the other turns abckward which i thought means no lsd so i dont think all 5 speed maximas have it
Old Nov 18, 2002 | 07:50 AM
RosenKen's Avatar
Look on the silver ID plate under your hood on the firewall (behind the engine). The tranny code should end with a V RS505 something V. Does it?
Old Nov 18, 2002 | 09:27 AM
Yeah, I definitely get torque steer when I redline 1st, especially when the motor isn't all the way warm and is still making the advertised 190 hp
Old Nov 18, 2002 | 04:05 PM
blackandwhite's Avatar
To them I'm like an idol
Nope. Turning one wheel forward and having the other go back means you do have LSD
Old Nov 18, 2002 | 04:07 PM
Jeff92se's Avatar
I'm needing a caw
I "heard" that not all manuals had lsd. I guess a tranny inspection would be in order. Also if one wheel turned the other way, it could also mean the viscous coupling had leaked some or all of it's fluid.
Old Nov 19, 2002 | 01:33 PM
that's one damn nice '93 SE by the way, rosenken
Old Nov 19, 2002 | 01:40 PM
Matt93SE's Avatar
STFU n00b!
Incorrect. ALL cars do that, LSD or not.
Yes, some VE 5 spds did not have LSD while others did.
to test (correctly) if you have LSD, jack up the front end and put the car in NEUTRAL. now spin the wheels. if they both spin the same direction, you've got LSD. if they spin opposite directions you don't have LSD.
If you do this test with the car in gear, the wheels will spin in opposite directions.
Old Nov 19, 2002 | 03:39 PM
Mine spin in opposite directions in neutral and I have the "V" .
Old Nov 19, 2002 | 03:41 PM
Jeff92se's Avatar
I'm needing a caw
You read my post right?
Old Nov 19, 2002 | 03:51 PM
Yeah, but what about the "V",? I was told about the "V" thing by a dealer when I ordered an axle seal.
Old Apr 30, 2003 | 08:14 PM
crazy4maxima's Avatar
bump! ok i get mixed info from this thread. some say yes all ve 5spd has lsd, some say not all. if by chance you finda ve 5spd that doesnt have lsd, can it be put on later on? or does the hole transmission have to be swapped?
Old Apr 30, 2003 | 08:29 PM
GReDdyXMaXiMa
I'm wondering , why r u guys worried about lsd thing ? What does lsd do with it however ? Out of curiousity .
Old Apr 30, 2003 | 08:39 PM
read up higher the answer is in theis post.. search for las and you find this post..lol.. that is why i posted in this thread since its being talked about. lsd=limited Slip differential... basically traction control.. both tires spin instead of one
Floktndr
Nov 30, 2015 07:48 PM
hyogong57
Apr 17, 2002 03:22 PM
skyjay617
Mar 12, 2002 07:57 PM
Eric
Jan 20, 2002 06:57 AM
Neptune97
Oct 24, 2001 03:36 PM
