Trying to bring Maxima back to life. Let me know if I am missing anything.
Old Nov 18, 2002 | 12:38 PM
my2ndmax's Avatar
Ok I bought a Pearl White 89 GXE that was really a piece of sh1+. I have since spent 800.00 on a new muffler and the entire pipe from the front of the car to the muffler because it was rusted. I replaced the fuel filter, air filter, oil change, engine flush, trans flush (think the trans was the only thing ever replaced in this car) And I have this ugly azz rust on the bottom of both of the fenders that I am about to replace. I am dropping it off at the dealer to have the Fuel filler recall done so that they can repair the rust and corrosion in my rear wheel wells.
I am about to order these parts from courtesy:
Timing Belt
3 Drive Belts
02 Sensor
and I need new fuel lines but I dont know where to buy them.
While having these things changed I will get these things checked:
Radiator hoses
Main Oil Seal
Tensinor
Water Pump
Cramshaft Oil Seal
Thermostat
PCV valve
Am I forgetting anything?
Old Nov 18, 2002 | 02:30 PM
nubiannupe's Avatar
OG Maxima.org Member
Hmmm... maybe the exhaust manifold bolts and engine mounts, but it sounds like you've got the most important stuff covered. Let us know how everything comes out.
Old Nov 18, 2002 | 02:41 PM
my2ndmax's Avatar
Oh yeah I forgot about the exhaust manifold bolts and engine mounts. Thanks I love this forum
Old Nov 18, 2002 | 02:44 PM
my2ndmax's Avatar
Oh yeah I forgot only one bose speaker works and the main panel dosent roll up any windows anymore other than the drivers. Its a work in progress but I will definitly take some before and after pictures once everything is done. After all of the mechanical stuff is done I may wait until summer but Im going with 18inch chrome. I had 17 on my 91SE but after my engine blew I sold them so I want to go bigger this time.
Also does anyone know where to get fuel lines I cant take this damn gas smell Im sure its from old cracked lines.
Old Nov 19, 2002 | 05:46 AM
GRNMAXDMON's Avatar
try and go to the junkyard maybe u'll have luck findin' fuel lines that r still in tact there.
r u sure it might be cracked fuel lines cuz i had a celica gt-s and i had the same problem but it wasn't the fuel lines, it turned out to be the top of the gas tank. but i may be wrong. good luck.
Old Nov 19, 2002 | 08:38 AM
my2ndmax's Avatar
Yeah it may be. Thats why I getting the fuel filler recall done. But I dont think the fuel lines have ever been changed anyway so Im going to change them even if the smells not coming from them.
thanks
Old Nov 19, 2002 | 01:29 PM
GRNMAXDMON's Avatar
well, just look into the gas tank thing cuz it might be that. cuz if u keep smellin' that its gonna get u dizzy up the azz.
Old Nov 19, 2002 | 05:16 PM
nismo-max500's Avatar
if ur plannin on moding this is a great time to do it.
any parts that have modified replacements should be put in. it will save u money. and u can mod it from the ground up. just a thought.
Old Nov 20, 2002 | 06:45 AM
5spd92SE's Avatar
Wasnt there some type of recall on the fuel filler neck? Nissan will replace it for free if it meets the proper conditions.
(Rusted, cracked, etc.)
Just an idea.
Old Nov 20, 2002 | 08:47 AM
my2ndmax's Avatar
Just an idea.
You didnt read the rest of the post did you? I already said that I would have that recall done.
Old Nov 20, 2002 | 09:51 AM
5spd92SE's Avatar
My bad!
- That brings up another question:
Why not wait and see if that fixes the problem before you replace all the fuel lines? Or replace the fuel lines, but I would use new ones, not used.
Old Nov 20, 2002 | 11:52 AM
cbpldc's Avatar
Actually, a buddy and I just did a head pull on a 1990 and not only did we break all the exhaust studs, but we also had two bad fuel injectors that were causing the smell of gas from under the hood.
Chris
Old Nov 20, 2002 | 12:12 PM
my2ndmax's Avatar
My bad!
Yeah I am going to wait until I get it back. But I dont think the fuel lines have ever been replaced and this is a 89. So why not
maxinout93
Oct 27, 2015 01:29 PM
Finkle
Sep 27, 2015 09:53 PM
Ray229Harris
Sep 16, 2015 08:16 PM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
