Is it safe for a 2 in drop
I am redoing the whole suspension this weekend. I got new shocks sruts, and springs but the springs I got say that it will lower my car 2 inches will this be safe with 16 in wheels I dont need to put these on and find out it will rub. Plus I am getting new tires. now uneven tire wear is a result of what? The 2 front of mine now are wore on the inside of the car. Some guy told me it cause I dont have the right amount of air in each tire is this true?
curious to know what springs you have that lower 2 inches. i thought sprint was only 1.8 inches and intrax 1.75. but i do know that suspensionmax a guy on ebay says sprint lowers 2 inches. idk maybe it's after they settle but yeh what set up and struts u got also? peace
Well i have Intrax springs (1.75 drop) and KYB GR2 struts and i have 16" wheels wrapped in 225/50/16 rubber, the drop and look is great but i experience a little rubbing but i think that is due to my offset. If you have a correct offset you will be fine...I think
-Mike
-Mike
I love the 225/50/16 better... i used to have 205/55/16 but i wanted wider tires for better grip and im glad i did it. The 50 profile isnt that much different from the 55 but i like the 50 better anyways
Well good luck in you decision.
-Mike
-Mike
Originally posted by Fosgate Fan
get your camber adjusted. i'm pretty sure that will solve the irregular tire wear.
Originally posted by VisualEvolution
I think it is i need a alignment cause my car pulls to the right. I am gonna try that first if that doesnt work with the new tires I quit.
Dano
Originally posted by Nismomaxt
You may want to keep in ming that if your running a wider tire then you may get some uneven wear due to the inability to adjust camber on the maxima. I was getting a little uneven wear and a small tug to the right. I took my car to a place with a laser allignment system and they alligned it perfectly, still pulls a little and I still experiance a little uneven wear. Well, at least the camber thing is my theory. Maybe someone can give me a more edjucated answer here.
Dano
Dano
you'll need proper equipment to be able to read the camber, but most alignment shops can adjust it a bit. there's some play in the two lower strut bolts.. loosen those and you can adjust it a bit. you can also drill out one hole a bit larger there and have more adjustment.. pretty common to see on cars that have been lowered quite a bit.
My Max is dropped and i havent wore out my tires "REAL BAD". I think the max looks good droped but it has to be done correctly. Before i got the tires that i currently have on the car i had a set of tires on the front for over a year and on the rear for 2 years.
maxima-junky
10-07-2015 07:13 PM
Andy29
09-29-2015 06:32 AM
