93 Maxima VG/VE engine blocks
Old Nov 22, 2002 | 06:41 PM
mattd32208's Avatar
I had figured that Nissan made a set of DOHC heads and installed them on the block in place of the SOHC heads in the Maxima for 1993.
I figured it would make more sense to do it that way because the cams for one thing are contained in the heads and also it would be cheaper because Nissan would not have to make a new block for the DOHC configuration.
If anyone has any engine breakdown sheets on the DOHC for the '93 Maxima please let me know as the Haynes manual that I have only shows the teardown of the SOHC engine.
Thanks in advance.
Mattd32208
Jacksonville, FL
Old Nov 22, 2002 | 06:59 PM
todamax's Avatar
Isn't that in the FSM?
Old Nov 22, 2002 | 07:07 PM
Nismo87SE's Avatar
Re: 93 Maxima VG/VE engine blocks
I know where this is going so I found this http://forums.maxima.org/showthread....gine#post4561. So in order for you to use DOHC heads you need a VG30 block made after 3/1987. Now assuming you get DE heads, how much clearance will be between the radiator and firewall? The search will guide you.
Thanks in advance.
Mattd32208
Jacksonville, FL
Hawkeye61
Aug 12, 2015 06:45 PM
Balkins
Aug 12, 2015 06:39 AM
laparka66
Aug 6, 2015 09:36 AM
BassAddictJ
Aug 4, 2015 11:38 AM
