restoring engine compression....
Old Nov 22, 2002 | 08:17 PM
AscendantMax's Avatar
did a search for this product but didn't find anything but anyways, i saw this product called Engine Restorer in my Motor Trend mag. It claims it can restore the engine's compression by coating the cylinder walls when u pour it into the oil. any opinions on this? i'm tempted to try it...unless there are potential negative side affects. anyways here's a link: http://www.restoreusa.com/restorer.html
~Fosgate Fan
Old Nov 22, 2002 | 10:35 PM
Nismo87SE's Avatar
If you ran a regular compression test, then added alittle oil to each cylinder and it increases compression. That shows the engine is suffering from worn piston rings. Generally products like that don't work well or sometimes at all. Do a regular compression test first.
Old Nov 23, 2002 | 02:01 PM
what are the changing intervals for piston rings? do i change them only when i notice performance decrease?
Old Nov 23, 2002 | 03:20 PM
eric93SE's Avatar
Wow, now that a Newbie question.
The max requires a lot of maintainance (just like every other car), oxygen sensor, knock sensor, Injector cleaning, Throttle positioning sensor, fuel filter, and the list goes on and on.
But to better answer your question, piston rings are only done when compression is bad, and that can only be guages with a compression test. Using good oil and doing oil/filter changes are the most important regular mainatanance items for any engine.
Piston rings should easily last 150-200k miles, on a well kept up car.
Old Nov 23, 2002 | 06:04 PM
i guess i'm still good for now. i got a little over 140K on the max and i change the oil and the filter every 3000 miles or so. thanks for all the input
Old Nov 23, 2002 | 06:31 PM
crazy4maxima's Avatar
but that is not to say there is damage or wear.. everymax is different just get it checked out. just like a timing belt could go at anytime... its just dependson wear and tear. how hard you drive. the length taht the part has been used for, the enviroment.
just to be safe get the compression test done... heck get a tune up and get the max checked up.
Old Nov 24, 2002 | 12:35 PM
yea i'll do it soon. i think the last tune up i did was last year. i'll make sure to get a compression test.
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
97_GXE
Sep 15, 2015 06:47 AM
seesole
Sep 14, 2015 12:38 PM
