E brake light
Old Nov 30, 2002 | 07:56 PM
CHIMAIRA90
E brake light
Yeah, my e brake light stays on continueously...(spell check) is it shorted out or do i need new rear brakes?
thanks,
-bijan
Old Nov 30, 2002 | 08:38 PM
AscendantMax's Avatar
is there enough brake fluid in the resevoir? are the brake lights out?
Old Nov 30, 2002 | 11:57 PM
jwtarbaj's Avatar
Re: E brake light
thanks,
-bijan
Yes like Fosgate Fan is asking the light stays on to indicate a problem with the braking system. If you have ABS it is NOT related to the ABS. It has it's own light. It is most likely low fluid level. Have the system checked for leaks ASAP.
Old Dec 1, 2002 | 08:18 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
low fluid...could be your pads are worn to about 80%...time to get in there and check things out
Old Dec 1, 2002 | 01:33 PM
CHIMAIRA90
alrighty, i'll get my fluids looked at. but if this helps at all...i don't have ABS. thanks fer your help fellas
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
