pioneers
Old Jan 1, 2001 | 12:08 PM
primeevil711's Avatar
Wussup everybody, i am redoing my audio setup and I have a 93gxe and i just got some new 6.5 pioneer 3ways and I was reading some past posts on speaker installation and I came across some talk of an "installation bracket" I just wanted to know what that means and/or what it's purpose is and i will be replacing the back speakers with pioneer 6x9 3ways and I'm doing all the installtion myself and any input is very welcomed, and as for bypassing the stock amp is that difficult. If it's possible can I get some links to some of your how to sites. Thanx alot
Old Jan 1, 2001 | 12:25 PM
Foo90SE
big question--do u have stock bose or non-bose
makes a big difference hehe
Old Jan 1, 2001 | 12:33 PM
Matt93SE's Avatar
STFU n00b!
if you've got the non-bose, here's how to bypass the amplifier in the rear..
http://www.ee.utulsa.edu/~mblehm/max...p%20bypass.txt
as for the installation brackets, once you pull off your fton door panels to remove the stock speakers, you'll see what we're talking about.. the oem speaker is a 4x6 up front.. you can either modify the bracket already in the door, or you could make a new one out of wood and fiberglass.. I recommend making a new one, as the thin plastic the stock one is made from won't hold up very well against a 6.5" speaker.. just too weak.
hope that helps.
Old Jan 1, 2001 | 12:41 PM
non bose
no bose here
Old Jan 1, 2001 | 01:15 PM
one more thing
how exactly do you take the front door panels off cuz I have to check my driver's side keypad too?
Old Jan 1, 2001 | 03:35 PM
Re: one more thing
I have a 93gxe non bose and I need to know all of the speaker sizes for front and back and how to take the door panels off.
Old Jan 1, 2001 | 08:01 PM
4x6
IF I PUT 4X6'S BACK IN THE DOORS DO I NEED TO MAKE INSTALLATION BRACKETS?
Old Jan 1, 2001 | 09:49 PM
Foo90SE
Hmm you'll probably have to make brackets any size u put..im not sure though..i made panels out of MDF for 6.5" speakers..they were kind of a tight fit though (window almost hits when i roll it down). In the back, for 6x9's, you'll have to get brackets out of a bose system car. The nonbose came with 6.5's back there and no brackets for 6x9's.
Im sure someone here has a website that has all this stuff on it but i dont know what it is
Old Jan 9, 2001 | 05:27 PM
hope that helps.
I just put the 6.5's in the doors and I'm going to be putting 6.5's in the rear but the problem is i need to know exactly how to go about that I know this seems like a stupid question but if i could just find out how to get those speakers in I would finally be done cuz right now I'm cruising with 2 good speakers and 2 blown cuz during the installation of the fronts my friend found out that all of my speakers were blown. i also want to know if an installation bracket is required for the back as well cuz I heard that the stock speakers are 6.5 so I figured that it should just be a simple replacement procedure......and BTW the pioneer 6.5 3ways are the best
Old Jan 10, 2001 | 01:35 PM
can anyone please tell me how to change the back speakers
Old Jan 10, 2001 | 04:52 PM
SOMEBODY HELP ME PLEASE!!!@!!
Old Jan 11, 2001 | 06:33 PM
«§»Craig B«§»'s Avatar
the back speakers are very easy to change; unplug the stock ones, then there are four small bolts that you have to access from the trunk that come off and then the speaker just pulls down
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
ivorton23
Sep 28, 2015 09:08 PM
