taking the A/C belt off...
Old Dec 18, 2002 | 05:45 PM
ChrisCheezer's Avatar
ok, im tryin to get at the A/C idler pully but i can't seem to drop the pully... i unscrewed that setter screw on top of the pully but i dont think it droped, well i couldn't get the belt off
.. i think im gonig to give it another try tomorrow,
- has anyone ever done this??
-plzzz help, should i just keep unscrewing ..?
Old Dec 18, 2002 | 06:31 PM
Spipedong90's Avatar
Re: taking the A/C belt off...
Take a block of wood and hammer and carefully hammer the idler assembly down. If the bolt is coming up, thats the sign its not dropping the idler. I've had to tap the idler down on both of my cars.
Old Dec 18, 2002 | 06:34 PM
GreenMaxVE's Avatar
You are supposed to loosen the bolt that goes through the center of the pulley, and then loosen the adjustment bolt to move it up and down. Good Luck
Old Dec 18, 2002 | 07:05 PM
DanNY's Avatar
Ad·min·is·tra·tor
yes loosen the center lock nut FIRST!
Old Dec 18, 2002 | 07:32 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: Re: taking the A/C belt off...
LOL yes... do not bang on it with a block of wood. Once you loosen the center nut.. then turn that screw that you've been turning and that will slowly move the pulley down the rail and loosen the AC belt. Then when you're done, make sure you tighten the center nut.
Old Dec 18, 2002 | 07:49 PM
What I meant is "Assuming you have loosened the center fastener do the following:"
Old Dec 18, 2002 | 08:20 PM
mykizism's Avatar
Freaking Noobs
Old Dec 18, 2002 | 08:32 PM
Re: Re: Re: taking the A/C belt off...
Anyone who doesn't do what you do is a noob I guess. It's a perfectly legitimate method of gently breaking free a part that has already been unfastened.
Originally posted by mykizism
Freaking Noobs
Old Dec 19, 2002 | 07:51 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: taking the A/C belt off...
ladies...stop the fighting.
it's like kindergarden in here!
u can use a block of wood to pop free a part...GENERALLY if your tensioner is that messed up (frozen) u should toss it. so in this case a block of wood should not be needed to pop anything.
Old Dec 19, 2002 | 09:12 AM
ok sounds good.
well im going to take it off and work on ther pully,
-is it ok to ride around with-out the A/C belt on?
Nismomaxt's Avatar
Re: Re: Re: Re: Re: taking the A/C belt off...
Block of wood worked perfectly fine on mine as well.
Old Dec 19, 2002 | 09:34 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: ok sounds good.
if it runs just the AC..no prob in the winter.
Old Dec 19, 2002 | 09:36 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: taking the A/C belt off...
you want a cookie?
i can use a 30lb sledge hammer too...what's your point?
most of the time you don't need it..if u do need something to break it loose then you might want to look into getting another tensioner since it's prob pretty old.
if u loosen the lock nut enough it should all move without a problem. did you do that?
Old Dec 19, 2002 | 09:38 AM
Jeff92se's Avatar
I'm needing a caw
Re: Re: ok sounds good.
No biggie for a short time but remember the AC is also the dryer for the defrost. Also it's the heater for when you put the defrost on "hot".
Old Dec 19, 2002 | 10:27 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: ok sounds good.
defrost? who needs that? just blow on it Jeff.
Old Dec 19, 2002 | 10:30 AM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Re: ok sounds good.
I'm not as good at "blowing" as you are Dan.
Old Dec 19, 2002 | 10:32 AM
Lordrandall's Avatar
@ Dan and Jeff
Old Dec 19, 2002 | 10:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: ok sounds good.
and u know this how?
ok u win..you are the "master-debater"
Old Dec 19, 2002 | 12:22 PM
WTF is wrong with you ppl .. nut jobs!
-using heat/defroster.. can i still do it with the A/C belt off?
... who defrosts without heat?? it makes no sence.. do you need heat to defrost your windshild?
Old Dec 19, 2002 | 12:24 PM
Jeff92se's Avatar
I'm needing a caw
Re: WTF is wrong with you ppl .. nut jobs!
Do you even know how your defrost system works?
Old Dec 19, 2002 | 12:27 PM
mmmm... food
i do not, but im thinkin it wouldn't be a problem with the A/C belt off.
Old Dec 19, 2002 | 03:23 PM
Jeff92se's Avatar
I'm needing a caw
Re: mmmm... food
I'm being a hater but you were planning twin turboing your car or turboing your car and you don't know how your defrost sytem works?
Old Dec 19, 2002 | 05:22 PM
Nismomaxt's Avatar
Re: Re: Re: Re: Re: Re: Re: taking the A/C belt off...
you want a cookie?
Well I guess my point was way to hard to get. Using a block of wood worked perfectly fine on mine. There does that clear up the confusion for ya? Now a 30 lb sledge, that would be just stupid.
Old Dec 20, 2002 | 06:25 AM
90 maxTT !!!! du...
lol.. do i plan to twin turbo my car?? i don't understand. my car has twin turbo chargers already. ddduuuuuu..
- anyway i took the belt off by taking loosening the pully, then it just slid down...EZ
-!BUT! I'm still getting that bad "hissssssing" sound from the belts..
humm... could my under-drive pully be making the sound.?
- o yea and just for the record i noticed a very slight gain in power, because the belt is off.
Old Dec 20, 2002 | 06:30 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: Re: Re: taking the A/C belt off...
like i said IF IT WORKS FOR YOU THEN BY ALL MEANS GO FOR IT. Do you want to be a PITA and give me all your techniques of breaking loose stuff?
the 30lb thing was a..ugh forget it, it's over your head.
Old Dec 20, 2002 | 06:35 AM
HYPE_MAX's Avatar
u guys r like my entertainment.. dis is like an online soap
Old Dec 20, 2002 | 06:44 AM
what do you expect....this is my thread
... god bless max.org
Old Dec 20, 2002 | 10:51 AM
Nismomaxt's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: taking the A/C belt off...
Good job "Moderator"
Old Dec 20, 2002 | 10:53 AM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: taking the A/C belt off...
no problem Maxima Enthusiast...always happy to help.
if you think i should be a model citizen you're dead wrong.
Old Dec 20, 2002 | 10:57 AM
Jeff92se's Avatar
I'm needing a caw
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: taking the A/C belt off...
I am NOT your kid's role model!
Old Dec 20, 2002 | 11:53 AM
Nismomaxt's Avatar
Hey its your credibility not mine.
Old Dec 20, 2002 | 11:55 AM
wow, if one small suggestion started all this shiz, just think what one of my 'brilliant schemes' would bring upon this forum.
Old Dec 20, 2002 | 01:14 PM
aa..... my BRAIN is melting!!
lolol!!! Y is thie thread still going!
05' MaximaMan
Oct 8, 2017 06:36 PM
BkGreen97
Apr 2, 2016 05:47 AM
markevans999
Oct 25, 2015 08:27 AM
2kmaximel
Sep 24, 2015 03:55 PM
EdRomo86
Sep 12, 2015 07:49 PM
