ECU keeps blowing! shortage!?!?!HELP
Old Jan 15, 2003 | 09:04 AM
Maxima90SE's Avatar
well i thought i fixed the problem by putting a new ECU but it did not solve the problem. what happened first is that the car would crank but not start, like it wanted to start but it couldn't. Last time the fuel pump did not work because the relay for the fuel pump was bad.So the mechanic told me the only thing that was wrong was the ECU shortage in the fuel system and it seems to mess up the ground. Now the pump works cause u can hear it but the car will not start. The fuel is getting into the car cause u can smell gasoline from the exhaust. So the relay must be good for the fuel pump. I think the ECU is blown again, but i dont know why. Isn't there a safety thing so the ECu wont mess up? There seems to be a short somewhere but i dunno where to find it. The short is dealing only with the fuel system. What should i look for in order to find the problem. WHAT TO DO!?
Old Jan 15, 2003 | 01:58 PM
Maxima90SE's Avatar
could it be now my inginition module? since the pump is working? I really need you help guys.
Old Jan 15, 2003 | 05:35 PM
Maxima90SE's Avatar
i dunno if it is called the ignition module, but what the mechanc told me is to check by pulling the plug wire and seeing if it sparks, if the guy installed my plug wires wrong could that made my ECU fry?
Old Jan 17, 2003 | 01:38 PM
Maxima90SE's Avatar
can anyone give me advice or help?
Old Jan 17, 2003 | 01:41 PM
Jeff92se's Avatar
I'm needing a caw
Considering you are selling 2k2 hids w/ broken tabs, I really doubt you will get the time of day here. I'm suprised no one flames you to hell and back.
Old Jan 17, 2003 | 09:42 PM
Maxima90SE's Avatar
well actually someone did buy them, BTW thanks for the help on my problem
Old Jan 21, 2003 | 09:36 AM
Maxima90SE's Avatar
so u guys wont help?!
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
gigabyte
Jan 6, 2017 06:05 PM
Noela
Sep 26, 2015 08:22 AM
