Had changed both Lower Ball Joints, what next...
I'm still having problem on my 92 GXE while turning right, but not left turn, although both left and right lower ball joints were replaced. So what else could be wrong? I mean I can hear something is striking something causing some bang noise while making a right turn, no noise while making left turn. The sound came from the left side near the tire or under the left side of hood...
thanks!
buzz
thanks!
buzz
sounds like it could be a bad strut bearing... or CV joint.. or control arm bushings... or a spring seated incorrectly.....
tear it apart and see if you can find the parts that are banging together and causing noise. if you can hear it, then there's enough impact that it should cause vivisble marks on the parts where it's happening.
thanks, Matt! You are the only one who replied to my post... :-)
yes, I will have to take the car to the repair shop for inspection, coz under that kind of cold weather I wouldn't do anything myself.
Thanks for the info!
Park your car, turn the wheels to the right, then look at the outside rubber boot on the driver side CV joint. If it's torn, then it's likely that CV joint has accumulated too much road debrise and is slowly disinigrating.
I know because mine is in the shop getting both CV joints and a clutch at this very moment...
Re: Had changed both Lower Ball Joints, what next...
thanks!
buzz
thanks!
buzz
good luck.
ag90fox
09-09-2015 12:22 PM
Violator
09-09-2015 10:14 AM
sdotcarter
09-02-2015 09:53 PM
