fog lights
Re: fog lights
Originally posted by lowmax4
has anyone found a after markey fog light that fits on the factory fog light bracket? I got a set of small light but I like the look of the larger square lights with the stillen front lip.
I bought 2 new ones for my car because one was rusted and busted and the other one looked bad compared to the new one.
fogs
i know this kinda doesnt have to do with your question, but i put hella 550 fog lights on my max for better lighting, and they look nearly identical to the stock fogs. they dont use the stock brackets though, you'll have to drill new mounting points. the hellas are rugged and bright to the point that i get flashed sometimes despite the fact that they are aimed down. they run about 70 bucks at most pep boys or autozones. ill try to get my cardomain page up so i can show you guys some pics of them. hope that helps
scott
scott
Re: fogs
scott
scott
Steve
Re: Re: fogs
Originally posted by 89sks
I was thinking of doing the same thing. The stock ones dont really throw that much light in my opinion. Did you just re-use the factory wiring etc. A write up and some pics would be great. I was hoping you could use the same bracket somehow. Thanks,
Steve
Steve
scott
Write up for installing Pilot 1055's into stock switch:
I know they're not the Hella's, but the procedure should be similar. This write up will allow you to use the stock wiring and a factory switch, so good luck.
My Foglamp write up
If this stuff doesn't work for you, I'm sorry. Just thought it's a good place to wiring info, etc.
dave
My Foglamp write up
dave
Re: Write up for installing Pilot 1055's into stock switch:
My Foglamp write up
dave
My Foglamp write up
dave
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
