Ignition Kill problem?!?
Old Jan 28, 2003 | 08:50 PM
maximum_mxma89's Avatar
i think i might have a problem with my ignition. every once in a great while my car wont start. its like you turn the car to on and nothing. no click just the regular acc power. i would assume it has something to do with the alarm and the ignition kill not turning off. im not at all sure on that though. it has been happening a lot recently. i recently found out the only way to start the car is to SHIFT_ it from park and change throught the gears and then it fires right up. if anyone could help me with a qick fix it would be much appreciated.
THANKS!
Old Jan 28, 2003 | 08:55 PM
Dark Lord Bunny's Avatar
Check a part called the neutral off switch, it's on your tranny. I ran into something like this last summer. At least you can kinda start it, mine was completely fried.
Old Jan 28, 2003 | 09:07 PM
how much did it cost to replace? thanks.
Old Jan 28, 2003 | 09:31 PM
darrick's Avatar
Dallas Nissan Enthusiast
are you sure its not the starter?
is it when the car is hot ,then you come back after it cools it starts back up?
Old Jan 28, 2003 | 09:35 PM
Re: are you sure its not the starter?
no the car isnt neccissarily hot when im able to get it to start. but aside from that, ive noticed its been running pretty hot lately. could that have anything to do with it?
thnks.
Old Jan 28, 2003 | 10:28 PM
Sorry, I can't find the invoice. But if I remember correctly it cost less than $100. $70ish... I think... don't quote me on that though. I'll let you know if I run across that receipt.
Old Jan 29, 2003 | 08:14 AM
eric93SE's Avatar
Re: Ignition Kill problem?!?
THANKS!
I had a similar problem and thought it had to do with the alarm. But it actually had to do with the shift selector not truely being in park. Try starting the car in neutral next time it happens to you. And if that works then you have broken/missing shift selector bushings, one is located where the cable meets the tranny and the other is under the car above the catalytic convertor. It took me forever to find out about the bushing above the catalytic convertor. Both bushing cost less than $5 total from the dealer.
Old Jan 29, 2003 | 12:58 PM
wyskibumm's Avatar
Re: Re: Ignition Kill problem?!?
The same thing has happened to me in the past. Goes like this, the car starts fine, and say perhaps I "accidently" stall out *cough cough* then i try to restart the car and the nothing. Like you said, no clicks or anything of the sort, just the acc on. Bad times. I've been trying to figure this out for a while, but since I rarely stall out, its never really a problem. I was told by a fell '91 5-spd owner that the little blue box near the master cylinder has something to do with this.
Old Jan 29, 2003 | 04:20 PM
thanks for your help. i think it might be the bushings because i have to kind of wiggle the shifter to get it to go into drive. i read that that is due to the bushings. ill have those replaced. thanks!
shilov
Feb 19, 2024 09:40 PM
mikeg75
Nov 30, 2015 05:12 PM
hozay99
Sep 19, 2015 10:20 PM
ajahearn
Sep 19, 2015 03:03 PM
rnb754
Sep 14, 2015 11:39 PM
