car won't start
Old Jan 29, 2003 | 09:31 AM
gold4dsc's Avatar
car won't start
ok last night i got back to my room at 12:00am then i went back out to my car and tried to go get some food. but when i turned the key the car doesn't turn over. i already got the fuel pump replace when this happend about three weeks ago and the worked but now its doing it again has any one else had this problem?
Old Jan 29, 2003 | 10:00 AM
shvelle's Avatar
Is the starter turning over? Do you just hear a 'click' and nothing more? Or is the motor turning over, but not firing?
Old Jan 29, 2003 | 10:07 AM
gold4dsc's Avatar
i don't think it is turning over its just making the sound like its about to start but when i try to help it out by pressing the gas there is no response
Old Jan 29, 2003 | 10:08 AM
shvelle's Avatar
You have to be more specific... You don't think what is turning over - the starter, or the engine?
Oh...., and don't ever step on the gas of a fuel injected vehicle to 'help it out' - not a good idea...
Old Jan 29, 2003 | 10:28 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
is it clicking or trying to start??
get a wrench and tap the starter a few times (lightly) and see what happens...it sounds like your starter is bad.
Old Jan 29, 2003 | 10:34 AM
shvelle's Avatar
Yeah, DA-MAX, that's what I was thinking too - but didn't wanna say without knowing exactly what wasn't turning over. Bet it's the starter solenoid - a LOT cheaper than the entire starter - especially if bought used.
Old Jan 29, 2003 | 01:57 PM
lophix's Avatar
If it's not turning over, then it might be the starter. the starter going out is a pretty common problem....personally, i'd recommend going to oreilly autoparts, buying a starter from them WITH lifetime warranty and learn how to switch it out yourself....doesn't take 10mins to do once you know how. That way if it EVER goes bad again, you can take it out and swap it with a new one under the lifetime warranty. GL
Old Jan 29, 2003 | 04:18 PM
gold4dsc's Avatar
ok can any one tell me how much is too much for the starter and where on the net could i find directions on how to change it
Old Jan 29, 2003 | 04:24 PM
gold4dsc's Avatar
i just did a found direction on how to change the starter so now i need to know what is too much for a starter
Old Jan 29, 2003 | 04:41 PM
DA-MAX's Avatar
buy it here its OEM at wholesale prices-->
http://www.parts.com/index.cfm?actio...Front&sfid=722
Old Jan 29, 2003 | 04:44 PM
gold4dsc's Avatar
i just found a used one for 45 bucks i might have to get this one seeing that my bank account is on E
Old Jan 29, 2003 | 05:50 PM
lophix's Avatar
again, i recommend your getting one with a lifetime warranty or a brand new oem one. The oem ones cost quite a bit but last a while...Apparently, some starters dont like cold weather...if you spend big bucks on one without a warranty and it goes out....well....you're s.o.luck.
my .02
Old Jan 29, 2003 | 06:19 PM
DA-MAX's Avatar
my .02
DEFINENETLY!!!!! you don't want to skimp on the starter of all things.
Old Jan 30, 2003 | 05:41 PM
markmaxima's Avatar
car won't start
make sure your factory alarm didn't set, this happened to me a couple of weeks ago, i set my non factory alarm, i later came back and clicked my remote to go inot my trunk, so i went into my trunk without opening the doors, it silently set it off, so when i tried to start it maid a noise and won't start, so i closed the door, locked with the key and unlocked, then it stared right up, doesn't hurt to try, normally when a starter is about to go, it gives you warnings.
Old Jan 30, 2003 | 05:43 PM
lophix's Avatar
Re: car won't start
why didnt you wire it into your new keyless entry/alarm?
Old Jan 31, 2003 | 07:27 AM
Airboss's Avatar
Re: car won't start
I have a VERY similar problem... Some mornings my car wont start. It ususally is moist, humid mornings. For me, my starter is good. When I turn the key, the starter turns, but its as if no ignition. It usually starts after 5 mins of starting. I think my problem is a electrical problem. Anyone let me know about reccomendations (1993 GXE)
Old Jan 31, 2003 | 11:18 PM
markmaxima's Avatar
Re: Re: car won't start
lophix, that is a good question i should have, i it hard to do?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
