Car stuttering -muffler? -frozen gas pipes?
Old Jan 30, 2003 | 01:10 PM
Aphrodisiac's Avatar
When I start my car and drive away my car stutters.
The RPM meter would go up and down from 0 - 2(x1000) repeaditly over and over. Frustrated I accelerate hard to see what happens, well turns out it won't go past 2500 Rpms for awhile (and my speed would gradually increase).
Then after a few seconds an instant burst would happen and I'd be at the 4-6(x1000)rpm mark and my speed would also burst.
After a while the problem will go away, probably about 10mins?
I checked my under the hood, no frost that my eye can see and the parts seem to work fine and the car isn't cold, like the engine etc..
In the beginning I thought my fuel line was frozen or something and water was getting mixed in as my car warmed up, but....
Today during the problem I decided to look underneath and discovered that white/transparent smoke (which looks like what would come out of the muffler) was comming out of the pipe that leads to the muffler, and they were, aswell, comming out at bursts (FYI the muffler seems to work fine)
I believe I lost some HP but can't confirm
Anyone have any inputs about this problem?
Old Jan 30, 2003 | 01:16 PM
Jeff92se's Avatar
I'm needing a caw
Clean the red temperature sensor connector connection. Use search to find the location. Info is also in the *cough* stickies *cough*
Sounds like your car is not going into the proper cold start program and once it's warmed up, it drives okay.
Also, see if the dist cap is wet(inside the cap) BEFORE you start the car in the morning.
Old Jan 30, 2003 | 01:18 PM
Gjohnson's Avatar
Man my car is doing the same thing. But its been doing this since I bought this car Dec 13. About 5 times a week. I've never look under the car when it happens, I'll try that. I don't know what to do.
Old Jan 30, 2003 | 03:16 PM
Thanks for the reply
I couldn't figure out where exactly this red temp sensor was
I did a search for heat soak and red temperature sensor and found only 5 threads. The best description of the location of the sensor was by Sawby4president:
"I had a '91 with a VG and I never bothered about the temp sensor, but I know on my '94 DOHC VE it's between the cylinder banks, toward the front bank, in front of the throttlebody assembly on the driver's side of the motor. There are two, a large red connector that goes to the ECU, and a smaller black one in front of that which goes to the temperature gauge. I have a hunch the set up is different on a VG, but the connector would probably look the same - a square-ish red thing with a black wire on top."
so I took the liberty to illustrate where they could be
(images taken from Edmax and matt93se, I hope you guys dont mind)
http://members.rogers.com/supanerds/Edmax_egbay.jpg
http://members.rogers.com/supanerds/...se%20egbay.jpg
is the red temp sens at 1, 2, 3, 4, or somewhere else?
Also this is where the smoke is comming out from, does this have any affect on my problem?
http://members.rogers.com/supanerds/...0underbody.jpg
Old Jan 30, 2003 | 11:59 PM
Torres's Avatar
hey Aphrodisiac
was it u that said that u had a broken bolt around that area???
Old Jan 31, 2003 | 11:39 AM
I dont believe so... but I probably do have a broken bolt my car is messed
Old Jan 31, 2003 | 11:41 PM
Torres's Avatar
hey Aphrodisiac
did u say ur from Toronto????
ur profile says On????
Torres
Old Feb 1, 2003 | 06:27 AM
Originally posted by Torres
hey Aphrodisiac
Torres
Yup smack dab in the corner of Scarborough
Old Feb 1, 2003 | 12:25 PM
Torres's Avatar
ok then we'll meet up at Pac Mall then and help Dev get a parkin' spot......
Old Feb 1, 2003 | 07:16 PM
I'll bring the fog horn, oh btw, I just bought a new car, its called the invizy by GM. Totally concept, NO GAS needed, all natural leg power!
(see GM commercial)
Old Feb 2, 2003 | 05:41 AM
98maxsel's Avatar
maybe heatshields? loose
Old Feb 2, 2003 | 09:09 AM
*blank stare*
Old Mar 3, 2003 | 11:18 AM
I finally fixed my hesitation, it was the O2 sensor
Old Mar 3, 2003 | 12:28 PM
TLM's Avatar
TLM
Thanks for the update... good to know that was what's wrong... I'm having similar problems...
Old Mar 3, 2003 | 12:40 PM
No problem
FYI in my opinion it feels as if I lost some power. I dont know from what tho. My car is kinda beat up as well it can be anything, or it could be psychological
meh
hope you get it fixed your self, check out that 02 sensor changing thread. Matt had a good DIY explaination of it all
oh, I also changed my Centre pipe, it had 3 holes in it (an update for one of those pics)
Old Mar 3, 2003 | 10:02 PM
Flipdoutmax93's Avatar
Destroying The Hopes And Dreams of Honda Owners Everywhere!
i had that problem before and i think its because the distributor cap is wet! thats what happened to me and i ended up having to buy a new distributor cap for like 300 or something to fix the problem. good luck in solving your problem.
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
