Extended-Life Timing Belt
A while back, I remember someone posting about an extended-life (90,000 mile) timing belt. I called my local Nissan Dealer and they said they had never heard of it. Does anyone know where I could get one of these? I've got a 93 GXE. Thanks.
Re: Extended-Life Timing Belt
Easiest thing, is go with what the book says for your car, I'd go OEM or NAPA.
Good luck.
Gates makes the timing belt with the rounded edges. www.carparts.com
Just use the one that Nissan or whoever says goes with your car per their Database. YOu can try and mix and match if you want, its only your engine your talking about if it breaks or doesnt work.
Bottom line you cant extend the life of the belt you have to use the one your car came with unless you change the sprockets. Like I said though I think that yours has the belt with rounded teeth.
Originally posted by 89sks
Yes thats true but it only fits certain years of the VG the others used the square edges and cannot be mixed from what I have read. Do a search to verify. I think the 93 has this type belt with rounded edges and its what was on in OEM in the first place. Thats why the VG's with this type (the last couple of years of VG) say an interval of 90k miles between changes.
Originally posted by jostack
I have 150K on my current timing belt
Originally posted by grody
do you realize thst since we have interference engines, when/if your timing belt does snap, your valves will collide with your pistons
What's the for? do you realize thst since we have interference engines, when/if your timing belt does snap, your valves will collide with your pistons, and you will either need a new engine, or have a very big repair bill for the one you have.
This has been a fabulous car, but it is showing its age and I just can't justify dumping a bunch of money into it.
tsi6001
10-03-2022 10:23 PM
Ray229Harris
09-16-2015 08:16 PM
Maxima2010 Prem
08-13-2015 11:34 AM
