again with the rebuild...
how much am i looking at for a rebuild? its real simple, i have low compression on the rear 3 cylinders, and i'd assume valve seals should be done along with rings, and whatever else usually gets done (T-chain/tensioner, waterpump, oil pump..).
how much should i be expecting to pay?
also, i am capable of pulling the motor and bringing to get rebuilt, so that should save a considerable amount of money.
thanks
thanks
Re: again with the rebuild...
thanks
thanks
Re: Re: again with the rebuild...
Originally posted by cneary812
if you can pull the engine yourself why not consider getting a new rebuilt engine and putting it in, depending on where you get it rebuilt it may turn out cheaper that way.
Re: Re: Re: again with the rebuild...
i'm looking for a ballpark on how much it'd be to rebuild...how much would a newer motor go for? i've seen decent VEs with less than 100k for upwards of $1900-$3000, i figure rebuilding would be slightly less expensive if i pulled it out myself.
i would guess depending on how extesive of a rebuild you get could be any where from 1k to 2k because parts are expensive fro the ve
Re: Re: Re: Re: again with the rebuild...
Originally posted by subs1000w
sh*t you could get a whole car for that much a ve with 96k went for 250 on ebay a few months ago if you watch for a while there will be more or check car-parts.com they have quite a few starting at 800 with 92k im my state so thats not to bad know where near the prices your talking about
Originally posted by male
You can get a nicely built Paeco short block for 2k. An that is a precision build piece. Look at the stage I and Stage II short blocks.
Re: Re: Re: Re: Re: Re: again with the rebuild...
Shipping crate motors is cheaper than you would think.
colinod
19
Dec 4, 2010 11:37 AM
alex1els
Jan 5, 2010 09:08 PM
maxedoutmax69
Sep 9, 2007 05:12 PM
