Catalyic Converter Gone Bad,Why?
Old Mar 30, 2003 | 09:26 AM
Starchild2k3's Avatar
I have a 1992 Nisan Maxima and I bought a Random Technology Cat Converter not even 2 months ago and Im getting a bad smell like a rotten egg smell and I heard its probably bad or clogged. I wanted to know what is likely to cause this problem so fast. Thanks
Old Mar 30, 2003 | 10:00 AM
Sudesh's Avatar
Re: Catalyic Converter Gone Bad,Why?
running rich..when unburned fuel gets on the cat..it burns the ceramic material in the cat. if the cat was clogged you would know it, you would have alot of idle problems.
Old Mar 30, 2003 | 10:49 AM
Yea I do have idle problems, the idle jumps up and down and I just got a timing belt change.
Old Mar 30, 2003 | 11:00 AM
Sudesh's Avatar
have it checked out..if it's still in good condition you can just get it flushed and cleaned up. alot cheaper than buying a new cat. It's also possible that your idle problems are purely coincidental, but no one here can know for sure, so it's best you have it checked out before a simple fix becomes an expensive one.
Old Mar 30, 2003 | 11:52 AM
propz''s Avatar
Cats arnt suppose to go bad if they do its usally bad rings causing oil to be passed into it, or possibly a bad injector.. Ever get a compression test done?
chisam14
Nov 6, 2018 08:56 PM
RealityCheck
Oct 2, 2015 06:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
