How do I fix my antenna?
I am a newb to the board and this has probly already been asked a thousand times. I need to fix my Power antenna on my 93 but I can't find anywhere that sells just the mast. SO, are there any other cars I can get a power antenna out of? What other model cars use the exact same power ant? Or can I buy just a mast somewhere? I tried using the search feature on this board but it won't let me. Says I am logged but I am not allowed to use it.
Re: How do I fix my antenna?
OE = original equipment (aka stock Nissan)
OEM = original equip manufacturer (or maybe manufactured)
you can get teh mast from any Nissan dealer and replace it yourself
www.4dsc.com/articles
my 93' max started having problem with the power antenna lately. since 5 months ago, i started hearing griding noise when the antenna retract from about 6 inches to complete retraction. it's ok.. cuz' it's just grinding noise. however, it started stop at 6" and can't lower anymore since last week. i read a lot of message regarding to replacing the antenna mast. i removed my antenna mast and found out the the antenna mast is at full length and still with gear on it. i clean up grease, and reapply new grease before re-inserting the antenna mast again with gear facing the rear of the ar. damn it.. it's even worse, the antenna only retract to 2 feet with 2 seconds of grinding noise and stop right there.. it could extend completely. why doesn't they antenna stop in the middle? if gear worn out, i should be hearing grinding noise longer.. what make the motor stop grinding? really strange.. any ideas?
