Sounds like my door is going to fall off
Old May 4, 2003 | 07:24 PM
ChrisCheezer's Avatar
Hey, I'm getting a odd "creaking" sound from my drivers side door, it's loud and happens every time I hit a bump, brake, turn.
-has anyone had this problem?
-what did you do to fix it?
any info will help.. thanx
Old May 4, 2003 | 07:35 PM
Matt93SE's Avatar
STFU n00b!
door hinges. buy new ones.
Old May 4, 2003 | 07:41 PM
James92SE's Avatar
2 VE's are better than one!
Maybe your cars body is rejecting the transplant of the Skyline tails
I think they make medicines to reduce the risk of your body rejecting things after the transplant
Old May 4, 2003 | 07:46 PM
AscendantMax's Avatar
kind of on the subject of door hinges, my driver side, rear door hinge creaks. so i just give it a quick spray of WD-40.
does WD-40 mix well with that left over grease on the hinges?
the creak was gone for like 2 days and it came back today.
seems like i have to get replacement hinges myself...
Old May 4, 2003 | 07:51 PM
eeeffffffff uuuuuuuuuu
"custom skyline tails" = +10 hp to the rear wheels
new door hinges humm..
is it a DIY job ?
thanx matt
Old May 4, 2003 | 09:06 PM
D-sta's Avatar
Re: eeeffffffff uuuuuuuuuu
you have a front wheel drive
Old May 4, 2003 | 10:37 PM
Re: Re: eeeffffffff uuuuuuuuuu
aww why you have to ruin his imagination?
Old May 5, 2003 | 07:10 AM
DanNY's Avatar
Ad·min·is·tra·tor
misconception - WD-40 IS NOT AN OIL...it displaces water and has light lubrication properties to reduce noise..but that goes away real fast.
get some white lithium grease and go to town..that should quiet it up for u.
Old May 5, 2003 | 07:30 AM
lophix's Avatar
i wish all the people who have argued with me on this topic would see this.
Old May 5, 2003 | 10:48 AM
yeah WD-40 worked!
i just put some on... it worked!!! for about 2 hours..
i guess ill have to replace the hindge...unless.... i carry a bottle of wd-40 around with me and keep lubing it up untill my door falls off.
nahhh ill replace it
-any tips?
Old May 5, 2003 | 04:00 PM
hmm...never knew that. thanks for that info!
Old May 6, 2003 | 04:05 AM
4DSC1989's Avatar
Door catch for the latch
There are square loops that are screwed onto the body of the car this is where the door latch hooks onto the body. They are covered with rubberize plastic. When the plastic is worn off the doors all raddle and shake when you hit a bump. Go get 4 new latch loops or hooks from the dealer, they are cheap. Screw them in and be ammazed how quiet the body of the car gets.
Old May 6, 2003 | 05:37 PM
Re: Door catch for the latch
nice, i hope its just that little part
- that black plastic piece is all torn apart, how much do they cost at teh dealer?
Old May 6, 2003 | 08:40 PM
4DSC1989's Avatar
door latch catch and doors that raddle
They are very cheap. Made a world of difference and very easy to change.
jsmith24
Feb 1, 2016 12:35 AM
Junebug1701
Sep 25, 2015 01:54 PM
lkiller123
Sep 21, 2015 03:00 AM
ajahearn
Sep 19, 2015 03:03 PM
