100W in foglights?
Old May 7, 2003 | 08:30 AM
midnight's Avatar
100W in foglights?
Has anyone had problems with this, such as wires/housing melting? Do you recommend this or just 55W? Thanks.
Old May 7, 2003 | 08:37 AM
Michael's Avatar
Back in a 3rd Gen.
NO DO NOT DO IT. Stick with 55W.
If you want to put 100W fogs in there you had better at least upgrade the wiring and use a relay.
Old May 7, 2003 | 08:57 AM
Gjohnson's Avatar
Man are you trying to blind somebody? Please don't tell me you are considering running 100W headlights along with 100W foglights. You'll most likely get a lot of tickets for that set up anyway. I don't know what the laws are in your hood, but around here cops will stop you just to tell you that your not suppose to drive with your foglights on, unless there is fog.
Ohh, and yes I do drive with my foglights on anyway.
Old May 7, 2003 | 09:01 AM
D-sta's Avatar
Most likely you will melt the wire harness....100w is a lot. Usually bulbs that run that high don't last too long either but its a must to upgrade the wire harness and relay like awsm66 said.
Old May 7, 2003 | 09:51 AM
midnight's Avatar
No, I'll be running silverstars soon, so not 100W headlights. I think I'll stick with 55W and not even venture towards 70 or 100 for the fogs.
Old May 7, 2003 | 11:18 AM
nubiannupe's Avatar
OG Maxima.org Member
Amen, brotha!
nubiannupe's Avatar
Amen, brotha!
Old May 7, 2003 | 05:24 PM
davebond007's Avatar
I have 80W/100W 9004 Hella bulbs on a custom harness with individual relays for the low's and hi's. I run 100W H3's in my foglights.
So fricken bright and clean. No problems here. I run with my headlights and foglights on all the time.
Old May 7, 2003 | 05:29 PM
GReDdyXMaXiMa
Well , u'll melt your wire soon
Old May 7, 2003 | 08:18 PM
MaximaBalla's Avatar
Old May 10, 2003 | 08:42 PM
ThurzNite's Avatar
can you explain the physics to why the harness will melt and why a separate relay is recommended?
Jae
Old Jun 21, 2003 | 07:20 PM
crazy4maxima's Avatar
basically the thicker guage wire will conduct better and transfere more energy effienctly. as opposed to using a thing gauge wire, too much heat and soo much energy going through that wire will litterly make it burn up, and will melt the plastic casing of the wiring, and then smoke and possibly a fire.
hrrm anyone knows how to upgrade the stock headlight harness? any write ups and pics of detailed step by step guild wih pics of wht you tap into?
Old Jun 21, 2003 | 08:50 PM
What does the headlight wiring harness have anything to do w/ the foglight wiring harness? If you want an upgraded headlight wiring harness, just go to Craig's website. http://www.prism.gatech.edu/~gte671n/mymax.html
Old Jun 22, 2003 | 02:41 PM
ChrisCheezer's Avatar
hehehe i run 130W fogs.. but i dont use them all the time.. only when its foggy
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
1997SENJ
Dec 4, 2000 01:27 PM
