3g VG30 mas air question
Old May 10, 2003 | 12:30 PM
Bryan H's Avatar
alright vg kids. i have a 95 pathfinder se now. the point in question on the motor is the mas air. its dinky and sucks.
now im thinking of swapping out mas air's with a maxima vg powered actually. is your mas three wires?
the on the path is 3 wires. same as the vq motors. this is a huge bottle neck right now on making power.
after the headers and full exhaust im looking around 200 hp with some other mods i have done so far.
any help would be appreciated
Old May 10, 2003 | 12:43 PM
Dark Lord Bunny's Avatar
Damn, I went downstairs to check it out but the wires are all wrapped so I cant tell you right now since I'm going out for errands in a few. If nobody else gets back to you I'll pull it off tonight and check it out.
And... if you don't know about them already. Spencer Low Racing carries a few goodies for your 3.3 VG truck needs.
Old May 10, 2003 | 12:52 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
its a 3 wire until you unwrap the shielded wires...
this is with the sheilding
http://www.sprintmax.com/albums/albu...1316.sized.jpg
this is how it looks with the sheilding removed...
http://www.sprintmax.com/albums/albu...1318.sized.jpg
Old May 10, 2003 | 01:51 PM
«§»Craig B«§»'s Avatar
the MAFS is the same for VG and VE (auto or manual)
Old May 10, 2003 | 10:49 PM
Nismo87SE's Avatar
Re: 3g VG30 mas air question
IF the maf is bigger than 60mm it isn't a power restriction. Your going to have to take my word on that one . The bottle neck would be the TB and the cams + heads. If you install a bigger maf, the engine won't run right unless you programmed the ecu for it. But then again I have full confidence in your abilities !.
Smackasmith
Feb 1, 2016 12:40 AM
conansriver
Sep 11, 2015 10:26 AM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
