Speedometer went dead...
Old May 13, 2003 | 09:27 PM
Mike92GXE's Avatar
I read somewhere that the search was back up, but I still get the same "no sir" when I try to access it. My speedometer went out and there are no trouble shooting directions in my Haynes/CHilton manual, it only said how to remove and replace a speed sensor cable. Would this be the only thing that would make my speedo go dead? And what was the final verdict on what to use in order to get the adhesive off when taking off the door moldings?
Old May 13, 2003 | 11:59 PM
azmalu's Avatar
recalibrating isnt too difficult matt blehm had some info onhis site for that and I think Chesto Cheu does too. I damaged mined too much when i tried so i bought a new one from a junk yard for about 40 bucks go to car-part.com sorry i know its not difficult but I cant remember how to do it.
Old May 14, 2003 | 05:43 AM
nismo1989's Avatar
If you're odometer doesn't work either it's probably a bad speed sensor. Don't assume it's the cable...
Old May 14, 2003 | 07:25 AM
jonnymax3's Avatar
speedo fix
Mine worked intermitently until it just stopped. If you take the speedometer sensor off the tranny you will see a black cap on the top of it, (the part the wires go into). somtimes this cap gets pushed out,I don't know why. all I did was put the sensor in a vise with one side on the metal lip and the other on the plastic cap and pressed it back in. there is a detent in the metal casing were the wires fit. It solved all the probles and didn't cost a thing. hope this helps.
Old May 14, 2003 | 03:17 PM
Clark_Kent's Avatar
Re: speedo fix
Is the sensor hard to take off? What is involved??
Thanks!
Old May 19, 2003 | 05:32 AM
TxMaxima93's Avatar
I have a 1993 and my odometer isnt working it stopped on 192,xxx. Will the FSM show me the details so I can get it back working again?
Old May 28, 2003 | 01:55 AM
Mike92GXE's Avatar
Re: speedo fix
If you could get me a few more details on how you did this it would be appreciated. My Manual doesn't have anything on speedometer not working other than the cable so i don't even know where to begin looking once I get the car up.
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
Jigaa
Jan 3, 2001 01:29 PM
