power everything problems
Old Jan 25, 2001 | 09:19 AM
abdiddy's Avatar
I just bought a 90 max se. The problem is that the power locks don't work and the front passenger side window and left back window do not work. Does anybody know what it could be and how to fix it. ThanX
Old Jan 25, 2001 | 09:22 AM
Jon91SE's Avatar
Pusssseeeehhhh
well im not sure i can say whats causing the locks to malfunction, but i woudl be taking a good guess on teh wondows whne i say its probably the regulator, happened to mine and many others. just replace the window regulator on both wondows and it shoudl work......
Old Jan 25, 2001 | 09:25 AM
«§»Craig B«§»'s Avatar
window problems are most likely regulator; if you can still hear the motor inside the door, but it doesn't move then it's probably that
as for replacing it, buy a new regulator ( I would suggest Courtesy Nissan http://www.courtesy-nissan.com) and go to my site for instructions and pics on how to replace it (click on my car and it's in the how-to section)
Old Jan 25, 2001 | 02:20 PM
mike_12_27_77
Door lock problem
abdiddy,
If you press the 'Lock/Unlock' button by the window controls and hear a clicking sound under the dash, but doors don't lock/unlock then the problem is probably the "Door Lock Timer". You can order it from Courtesy Nissan (same place the other people told you to go for the window regulator). If they ship it to you it should be about $60. DO NOT take it to get installed - do it yourself. I called a local Nissan dealer and they wanted $292 JUST FOR LABOR. I did it myself in about 20 minutes. If you need instructions after you get it, e-mail me.
Mike-
P.S. - I just remembered reading that only '92-'94 models have Door Lock Timers, if that's true then this can't be your problem. You might want to check it out though.
[Edited by mike_12_27_77 on 01-25-2001 at 04:29 PM]
lowpost99
Oct 26, 2025 06:53 PM
DJLAX152
May 4, 2021 11:46 AM
cruce91
Sep 20, 2015 10:23 AM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
