foglights on a gxe
Old May 28, 2003 | 10:30 AM
midnight's Avatar
foglights on a gxe
Is the wiring already there in a gxe, or just the relay? Thanks.
Old May 28, 2003 | 12:30 PM
Michael's Avatar
Back in a 3rd Gen.
all the wiring was there on my 92GXE. I put a switch in hooked up the lights added the relay and fuse then was good to go.
Old May 28, 2003 | 08:28 PM
arsalanaltaf's Avatar
Where was the wiring? Also where on the dash did you put the switch?
Old May 28, 2003 | 09:18 PM
Michael's Avatar
Back in a 3rd Gen.
I put a factory switch in the factory hole plugging up the factory wires.
To the left of the steering wheel there is a space that is filled with a blank plastic piece. That piece comes out and you can put the factory switch in (get at a junk yard or something). The wires for the fog light switch was behind the dash around the area that the switch is...its probably taped up back there somewhere.
The plugs for the fogs themselves are taped to the wires going to the corner lights. Take your splash shield off and you will see them.
Its all plug and play IF you use factory lights and switch.
Of course you can put aftermarket lights on too with or without using the factory wires.
Old May 29, 2003 | 07:36 AM
davecmu's Avatar
Read This
awsm66 is right.
My Foglamp Install Write-Up
Read this page. Hopefully it will help point you in the right direction. It is a write up I did for installing aftermarket fogs into the stock location on a GXE, including using the stock switch and relay, but may also answer some of your other questions.
Dave
Old May 31, 2003 | 01:25 PM
Thanks for the post, I will let you guys know how it turns out. That write up is VERY informative and complete.
tarun900
19
Dec 20, 2021 06:57 PM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Socalstillen
Sep 20, 2015 11:46 PM
