Putting in a new fog lite bulb
the procedure isn't that hard, it's just getting to it that's the problem
you will have to lay down under the car and if you look up at the back of the foglight assembly, there is a bolt on each one that goes sideways (from one side of the car to the other as opposed to front to back). Remove that bolt and I think there are 2 screws that go straight up into the bumper that you have to take out too. Once that is done, you should be able to remove the fog light assembly which just has two screws on the back. Also, when you replace the bulb, don't touch it with your fingers because it will get oils on it that will cause it to break and you will have to go through this crap again; if you do touch it, you can clean it with rubbing alcohol.
hope that helps and good luck
The Frye
09-02-2021 11:03 AM
