Won't start after VTC grounding
Old Jun 6, 2003 | 10:20 AM
Canmedic's Avatar
Finally got tired of the ticking, so I did an oil change and decided to ground the VTCs. Ran the wire from the red vtc wire to a grounding
location and the car won't start. Took the wire off and still won't start. I can hear the relays in the fuse bos opening but the car will not turn over. Any ideas?
Old Jun 6, 2003 | 10:27 AM
subs1000w's Avatar
check all your fuses
Old Jun 6, 2003 | 10:47 AM
Michael's Avatar
Back in a 3rd Gen.
Re: Won't start after VTC grounding
man you grounded the wrong wire. Did you read the directions on how to do this? You are supposed to ground the yellow/green wire.
Hopefully you just blew a fuse. Check all the fuses and then if it starts ground the correct wire.
The red wire is the power wire so like I said hopefully its just a fuse but if its not you could have other problems in the wiring because you are never suppose to short a power wire.
good luck
oh and here is Craigs site to help you with the re wire
Old Jun 6, 2003 | 11:32 AM
Canmedic's Avatar
Thanks guys it was the eng con fuse that was blown. Note to self, get sleep first before reading(or trying to) read directions. The car sounds a heck of alot better.
Old Jun 6, 2003 | 11:44 AM
Michael's Avatar
Back in a 3rd Gen.
cool glad it worked out. We all make simple mistakes like that sometimes.
Old Jun 7, 2003 | 05:12 AM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by awsm66 cool glad it worked out. We all make simple mistakes like that sometimes.
Yeah he got lucky, if that magic smoke would have appeared. SOL
But I guess they make circuit protectors for those who are sleepy
pktaske
May 6, 2016 07:49 AM
markevans999
Sep 10, 2015 04:29 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
pktaske
Sep 4, 2015 08:40 AM
