Changed my belts and...
Old Jun 6, 2003 | 11:02 AM
MaximaGuy719's Avatar
Before I changed my belts they were making a terrible squeaky noise, like a bunch of mice. So I got them changed and now I'm still hearing that noise from that area, not as bad but it's still there. The belts needed to be changed anyway, but what else could be making the noise? Or do the new belts just need to be worn in?
Old Jun 6, 2003 | 11:09 AM
Michael's Avatar
Back in a 3rd Gen.
Re: Changed my belts and...
the bearings in the idler pulleys are probably going out. Or I guess one of the accesories or water pump could be bad too.
I would bank on one or both of the idler pulleys though...if someone overtightened the belts they will wear out faster.
Old Jun 16, 2003 | 02:58 PM
Re: Re: Changed my belts and...
Do you have any idea of how much it would cost to get done?
Old Jun 16, 2003 | 03:07 PM
Gjohnson's Avatar
I bought an idler pulley from the nissan dealership last week and it ran me $52.00, easy to install.
Old Jun 22, 2003 | 10:38 AM
Should I just listen to which pulley is making the noise and change that one? Or is there any other indication of a pulley going?
Old Jun 22, 2003 | 12:46 PM
Matt93SE's Avatar
STFU n00b!
remove the drive belts one at a time until the noise goes away.. that will let you know which group of pullies is causing the problem. I was hoping mine was an idler pulley, but nope.. alternator bearings. ugh. least there's a place here in town that will replace the bearings for about $40.
if it winds up being the idler pulleys, press the bearing out (use a bench vice), then call a bearing supply place and order a new bearing for it. there's always a number stamped on the side of the bearing.. just take it in if you've got questions about it and they'll get you the right one. last time I changed an idler pulley bearing, it cost me $12, not $56.
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
RWCreative
Sep 21, 2015 11:01 AM
carid
Sep 17, 2015 05:00 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
