Will 85/80 watt bulbs melt the harness?
Old Jun 29, 2003 | 10:31 AM
pezking4's Avatar
Got some free head light bulbs, but I don't know if I can risk burning up my stock harness. Anybody runs this wattage safely on the stock headlight harness?
Old Jun 29, 2003 | 10:55 AM
AscendantMax's Avatar
Re: Will 85/80 watt bulbs melt the harness?
they won't fry right away, but they will pretty quick.
Old Jun 29, 2003 | 11:36 AM
Maxima90SE's Avatar
it will take about a month, depends how often u use headlights..just check them and make sure if they are not, when they do burn ur light will go on and off until it quits working.. a new harness is about 6 bucks
Old Jun 29, 2003 | 11:40 AM
JDwyer2821's Avatar
Thats about what happened to me but it took two months. I gave the bulbs to my friend with a 4th gen and it only took 2 weeks to burn out his
Old Jun 29, 2003 | 01:16 PM
pezking4's Avatar
Any suggestions on an upgraded harness? SW autoworks has them for somethign like $15. Where did you see them for $6?
Old Jun 29, 2003 | 02:21 PM
Michael's Avatar
Back in a 3rd Gen.
He is saying the factory plugs are $6 from a auto parts store.
dont use the ones from SW autoworks because they are just harnesses. I would recomend using the ones with the relays and all. That way you get a good strong voltage to the light and if something does happen then the rest of your harness is protected.
here is the link to the harness I got.
Headlight harness
I highly recomend this part. It is high quality and easy to hook up.
Old Jun 29, 2003 | 08:15 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
yeah don't be lazy...upgrade now and be done with it
Old Jun 30, 2003 | 10:00 PM
Flipdoutmax93's Avatar
Destroying The Hopes And Dreams of Honda Owners Everywhere!
i did the mod with the same ones awsm66 has with the relays and all and it looks great, much better than stock, although the high beams dont work right. Its ok cause the lights are bright enough where you dont even really need the high beams that much. The light also looks nice and white and there is no splicing involved. all you really need to get this done is grounding it to the car and there are plenty of spots near headlights to do so. then after that is basically plug and play in to the old socket and your done. I guess the only lighting mods that are better are hids and the bmw headlight conversion.
Old Jun 30, 2003 | 10:58 PM
Michael's Avatar
Back in a 3rd Gen.
Still dont understand why the high beams dont work on some of the 9004 set ups. I have the 9005/9006 setup and my high and lows work perfectly.
Old Jun 30, 2003 | 11:18 PM
for the 9005/9006 setup how did you splice them to make it work with the stock headlight setup? i'm wondering because i may upgrade the harnesses when i do the euro spec bmw headlight conversion in the next few weeks. i imagine you would just get one headlight harness for each light like one 9005 and one 9006 and just plug the upgraded harness to that or what? it that way or is there another way to do it? i figure if im upgrading to bmw headlight i might as well buy another new harness since the color output looks good on the stock i imagine its even better with the bmw's.
Old Jul 1, 2003 | 07:16 AM
Michael's Avatar
Back in a 3rd Gen.
yeah I just did the high and low beam wiring for one side by using a meter to find out which wire was high and which one was low and then just connected the harness.
Old Jul 22, 2003 | 02:47 PM
pezking4's Avatar
Just got my 9004 Harness from autodynamic.com
It's clearly soooo much better quality than our stock harness. WOW!
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
