installing distributor
Old Jul 9, 2003 | 09:28 AM
gold91's Avatar
I recently replaced my 91 3.0 with a 93 3.0. The 93 did not come with a distributor. I.'ve already found TDC, but I need to know do I point the rotor to the #1 wire on the dist. cap, then install it. Or does anybody know the steps to do this. This is the only thing from keeping me from driving my maxima.
Old Jul 9, 2003 | 01:06 PM
Matt93SE's Avatar
STFU n00b!
buy a service manual and it'll tell you how in there. I find it hard to believe you've gone this far in replacing an engine without one.
Old Jul 9, 2003 | 02:18 PM
gold91's Avatar
I have a Haynes manual, but it's pretty vague. Putting in an engine is fairly simple.
Old Jul 9, 2003 | 09:44 PM
Nismomaxt's Avatar
Just did mine,
On the distributor base/shaft (just below the teeth) is a punch mark between the two locking pin holes. On the dist. case are two lines (just above the teeth), one recessed and one extended. Line up the extended line with the punch mark. Insert dist., it should start now, and set timing with a timing light for 15 degrees BTDC (or what ever the timing plate says for your engine). Thats the best way I can explain it...
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
