If we have front wheel drive why do the back tires go bald first ???
Old Jul 25, 2003 | 09:17 PM
ILOVEMYSE's Avatar
If we have front wheel drive why do my back tires always go bald first
Old Jul 25, 2003 | 09:19 PM
crazy4maxima's Avatar
are you certain that the rear tires are aligned, and balanced.? if not then that is your problem, or that your doing too many ebraking
seriously, the fronts should die before the rear, more load and more use in the front. make certain that you rotate the tires every 5k or so.
Old Jul 25, 2003 | 09:37 PM
pjalst
Re: If we have front wheel drive why do the back tires go bald first ???
That happens when you drive in reverse all the time.
Old Jul 26, 2003 | 04:30 AM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by ILOVEMYSE why do my back tires always go bald first
Because "you" have an alignment issue with the rear. My guess your rear tires aren't wearing down evenly. Is it wearing down on the sides?
Old Jul 26, 2003 | 05:05 AM
MrGone's Avatar
even on my dads 98 durango the fronts tend to wear quicker than the rears because of the turning, then again it could just appear that way because the tires do turn, taking more of a cross bite out of the tread.
getting on the gas quickly changes wear patterns though
along with what Izzy said, check tire pressure.
Old Jul 26, 2003 | 06:03 AM
ILOVEMYSE's Avatar
Thanks guys I will check the tire pressure and have the alignment checked because my rear tires are bald and my fronts stil have a lot of tread left.
Old Jul 26, 2003 | 01:00 PM
JC93SE's Avatar
If you rotated your tires on a regular basis like you're supposed to (at least 5K, but no more than 10K) all of the tires would be wearing out at about the same time. BUT, they'd still be wearing out quickly because of your alignment problem.
Make sure your struts aren't wiped out too, though that doesn't sound like the problem here.
twotonezed
Aug 16, 2015 11:41 AM
criminalslang810
Aug 16, 2015 08:12 AM
mls277
Aug 11, 2015 07:18 PM
BassAddictJ
Aug 4, 2015 11:38 AM
