injectors and coil
Old Aug 11, 2003 | 09:25 PM
Irish's Avatar
This is a democracy
injectors and coil
just had a dyno ran on the ECU, had an unpleasent suprise. found out that my #4 fuel injector and ignition coil needed to be replaced. the injector was 75% clogged and the coil was burnt out.anyone had similar bad luck?
Old Aug 12, 2003 | 06:21 AM
Gjohnson's Avatar
I didn't realize that a bad coil would give you a code on the ECU. I have two replacement coils that I have to pick up from autozone today, because the coils in my 2nd and 4th cylinders are both cracked. I never recieved a code for either.
Old Aug 12, 2003 | 06:32 AM
tool46&2's Avatar
When you say you had a "dyno ran on the ECU" what specifically does that mean? Are you referring that you had a mechanic hook up the "Consult" computer to your car? Or are you referring to something else?
Old Aug 12, 2003 | 06:39 AM
Gjohnson's Avatar
I figured he meant a diagnostic test. But there I go again assuming.
Old Aug 12, 2003 | 08:55 PM
Irish's Avatar
This is a democracy
gjohson is right, my bad on the "dyno" there wasnt a code for the coil, it just came up that there was something wrong with cylinder 4, and he checked the coil by moving it to a different cylinder and then he found out it was bad too when the computer said there was something wrong with 2 cylinders
Old Aug 12, 2003 | 10:33 PM
maxdout92se's Avatar
i didn't know autozone sold VE coils....how much are they????
Old Aug 13, 2003 | 07:01 AM
Gjohnson's Avatar
They are $60 for the front and I believe $62 for the back. I just picked up two yesterday that I had ordered on Saturday. Car runs great now!!!
Old Aug 13, 2003 | 07:35 AM
alane's Avatar
i know what an injector is, ive replaced a few before, but what is this coil that you guys speak of? its obviously not the ignition coil that sends juice to the distributer.
Old Aug 13, 2003 | 07:55 AM
subs1000w's Avatar
on the ve there are six ignition coils one for each cylinder its soppose to provide less spark loss than with spark plug wires
Old Aug 13, 2003 | 07:59 AM
alane's Avatar
interesting
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
