what is wrong with my Maxiam?
Tonight some strange things happened to my Maxiam 93. When I turn the signal switch, the light is on but it does not flash. At the same time, the panel became dark once in while. Finally, I found that my security system does not work, including the keyless entry when I turned off the egnine. The battery should be ok since the headlight is OK.
Can Someone tell me possible problems? I am afraid that there is some problems in my electronic systme.
Thanks a lot!
Thanks a lot!
my step father has a nissan pickup and it did the same thing to him turned out to be some harness on the battery cable apparently Nissan has this and most other cars dont.it went bad and he had all kinds of issues... got it replaced and all works like new!!
It could be your alternator. Mine panel used to get dark once in a while and my battery died out. So I got it charged again and the car died again. Ended up being the alternator. Check with autozone. I think they can have it checked for you for free
Forge277
Jun 13, 2016 09:26 PM
bigfrank
Oct 1, 2015 12:51 PM
pears
Sep 18, 2015 05:25 AM
