trunk does not open by pressing the button
Old Aug 21, 2003 | 05:32 PM
stillenmax's Avatar
Does anybody have this problem? My trunk won't open by pressing the button on the door. I hear the clicking sound, but nothing happens.
Old Aug 21, 2003 | 07:28 PM
Ninty-two-se's Avatar
This may be due to the fact that the remote trunk release is manually disabled at the latch in the trunk... open your trunk up and locate the little square hole on the part of the latch that is connected to the car,(not the trunk lid) this should be down on the carpeted side of the latch, reach in and find a little lever and pull it up... this should turn on the remote release and allow you to open it by pushing the button... if that doesnt work then you're on your own.
Old Aug 21, 2003 | 11:38 PM
DARHAW-MAX's Avatar
Daym , I did not know that. Good info for the future.
Old Aug 22, 2003 | 12:22 PM
Did that work for you stillenmax?
Old Aug 22, 2003 | 06:50 PM
ghostmax's Avatar
Re: trunk does not open by pressing the button
I have the same problem. Ever since I installed my keyless entry, it seems as if the trunk pop isn't getting enough power. The only time the button works is when the car is on with no accessories. I have a UDP which may or may not be part of the problem.
Old Aug 25, 2003 | 11:20 AM
charbroiled91's Avatar
25 Cent Trunk Release Fix
i had this exact prob when i first bought my 91 (used). if you hear the solenoid clicking but not popping the trunk, your release cable is probably stretched like mine was. this is how i fixed mine (cost about 12 cents)...
1. open the trunk and remove all the carpeting trim on the trunk wall closest the bumper. 6 screws and 4 fabric clips.
2. as you face the rear of the car reach down and remove the cable from the release mechanism. this is done by grabbing the cable with needle nose pliers or what have you and pulling the cable to the right (passenger side) and then lifting up. you will see the cable routing in the mechanism.
3. there should be a lead/metal ball on the end of the cable with a little rubber washer right in front of it. move the little washer away from the ball. (DO NOT REMOVE THE RUBBER WASHER!)
4. take a 1/4 oz. split shot (or two depending how stretched your cable is) from any fishing tackle box and firmly crimp it over the cable between the rubber washer and the ball. then pull the washer snug up to the split shot and reinstall the cable into the release mechanism.
5. IMPORTANT - make sure your keys are in your pocket before you close the trunk to check out your work.
6. close your trunk and try your remote release button.
hope this helps you out. good luck
Old Aug 25, 2003 | 02:37 PM
ghostmax's Avatar
Re: 25 Cent Trunk Release Fix
Originally posted by charbroiled91
Thanks, but I think my problem is electrical. If I'm idling and hit the button, it sometimes will pop depending on if I have the radio, a/c, etc. on. If I turn everything off, it'll pop most of the time. If that doesn't work, I'll rev the engine, and it'll pop everytime. Messed up. I probably didn't install the keyless entry quite right.
Old Aug 26, 2003 | 05:48 PM
spencediggy's Avatar
thanks .......i just tried it out....i have no idea!!!!!11
Old Aug 26, 2003 | 06:27 PM
which one did you try?
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
