brake squeal, how long til i must change the pads?
Old Aug 22, 2003 | 02:01 PM
AscendantMax's Avatar
my brakes just stated to have that squeal during low speed braking. think it's time to replace the pads, but how long do i have left in the pads til i risk losing braking performance? thanks in advance
Old Aug 22, 2003 | 02:06 PM
MrGone's Avatar
it doesnt always mean you need to replace your pads.
alot of the time is the pads making viberations against the calipers that cause the squeel.
Go find some brake grease (I think that's what its called, its been awhile), then you take a wire brush to clean where the calipers meet the pads, then apply a thin layer of the grease to the area's you just cleaned.
I'll try to get some better instructions, I havent done it on the Maxima yet so I cant really help out too much
Old Aug 22, 2003 | 02:22 PM
Jeff92se's Avatar
I'm needing a caw
Exactly 1345.11 miles before complete failure.
Suggestion. Jack up front, take one wheel off, undo 1 bolt and check pads. "Might" take 10 min if you are slow
Old Aug 22, 2003 | 02:23 PM
Matt93SE's Avatar
STFU n00b!
don't ask, just look and see for yourself. if they're worn, replace them. If they're not, sand the glazing off and put them back in.
matts95max
Apr 23, 2025 10:44 AM
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
