Broke or Not???
Old Aug 23, 2003 | 03:08 PM
maximum_mxma89's Avatar
Broke or Not???
today while i was driving i rolled down the left rear passengers window and i heard a pop, and then the window wouldnt roll back up. Now when i press the button all i hear is a motor noise. My question is, did the regulartor go out or is it just off the track? If the regulator went out, i wouldnt hear the motor trying to pull it up would I? thanks. (and if its off the track, is it any easy fix?)
Old Aug 23, 2003 | 03:13 PM
mtcookson's Avatar
it's probably your regulator. those are extremely common to go out. you can just pull your door panel off to find out.
Old Aug 23, 2003 | 03:33 PM
yeah, everybody seems to complain about them going out. how would i be able to tell if the reg. is bad by pulling off the door panel? what would i look for. thanks for your help.
Old Aug 23, 2003 | 03:51 PM
LittlePiggie's Avatar
if the motor moves, but the window doesn't, it's your regulator.
Old Aug 23, 2003 | 03:58 PM
dangit, i was hoping it wasnt the dang regulator, but i guess it is. thanks for the help.
Old Aug 23, 2003 | 04:15 PM
yeah, here it costs 95 for the front and 109 for the back. not too bad I guess
Old Aug 23, 2003 | 06:29 PM
«§»Craig B«§»'s Avatar
you can get them much cheaper from www.courtesyparts.com
Old Aug 24, 2003 | 06:56 PM
subs1000w's Avatar
also cheap here http://cgi.ebay.com/ebaymotors/ws/eB...category=40018
Old Aug 24, 2003 | 09:52 PM
maxdout92se's Avatar
mine pops when i roll my window window up (they still work though), what is that signifying?
Old Aug 24, 2003 | 10:12 PM
Cliff Clavin's Avatar
Way out West
I bought a regulator off ebay and it was nice because it came with a new motor, too. Hunt around, they are on there. I paid around $60 shipped for it, but it was a driver door. I wouldn't recommend buying one from a "stealership." You could almost afford two ebay units for the price of one.
Maxedout -- when I took mine apart, I noticed that there was a big chunk broke off one side of a plastic pulley, releasing the wire and dropping my window suddenly. There were several pieces of broken pulley in the bottom of my door. Maybe that's what your popping is.
Old Aug 24, 2003 | 11:45 PM
so i pulled my door panel off and theres no way i can get to the dang regulator. my window is stuck half way down. not good seeing that i have to park outside. if i could just get the damn window up, i dont care if it works or not. i guess im going to have to take it to the 'stealership' and get ripped off.
Old Aug 25, 2003 | 06:40 AM
NismoDrew91SE's Avatar
yes, dont go to the dealership for these. We've had my maxima 13yrs now and have had to replace all of them, they kinda all went bad in a clockwise fashion throughtout the car. i think the dealership charged 150++ for the first one. Then when the 2nd went bad, just said **** it and bought the part ourselves. very easy install
Old Aug 25, 2003 | 07:03 AM
Way out West
look in the 3rd gen FAQs at the top of this board, there are a couple of guys that have step-by-step intstructions on how to do it. Just takes like an hour (first time -- I know some of you can do it in about 15 min. now ) with a couple of very common tools (a phillips screwdriver and I think a 10mm socket/wrench, maybe something else...can't remember).
Old Aug 25, 2003 | 12:55 PM
MerkMax's Avatar
i used a regulator from courtesyparts.com on the drivers side rear. only took about 45 min.
Old Aug 25, 2003 | 02:18 PM
ok. ill attempt to do it myself. this could take a while. how can your work your way around inside that tiny door panel.
thanks for the help
Old Aug 26, 2003 | 07:42 AM
MerkMax's Avatar
the regulator will almost drop out when you unbolt the motor and regulator. try to pull the bottom of the regulator out first .
Old Aug 26, 2003 | 08:00 AM
Matt93SE's Avatar
STFU n00b!
it's not hard at all. the window is just barely held in there because the regulator is the part that holds it- and it's broken.. grab the glass and pull the window up while you're holding the up button. when it gets near the top, you'll need some way to hold the glass up.. usually I stick a piece of cardboard into the weatherstripping near the edge of the window, then pull the window up around it. it'll hold it there long enough to get the regulator out.
when you unbolt the regulator, you'll see how it comes out. hint: there's a big open rectangle at the bottom of the door. it's your friend.
only tools you'll need are a 10mm and a #3 phillips. break them all loose with the 10mm, then use the phillips to remove them easier.
Old Aug 26, 2003 | 03:04 PM
thanks matt. the window was actually stuck half way down and it couldnt get it up, so we took it to a glass shop and they were able to get it up. all i need to do now is find a cheap regulator off ebay and try to install this ****. thanks for the help.
MaxDD
Sep 24, 2015 06:40 AM
220k+ A32
Sep 23, 2015 03:38 PM
dcam0326
Sep 18, 2015 04:52 PM
seesole
Sep 14, 2015 12:38 PM
