Alarm goes off opening truck w/ key
Old Aug 23, 2003 | 11:05 PM
Tom's Avatar
Tom
Basically, if all the doors are locked and I open the trunk with a key, the alarm will sound.
The keypad on the door comes in real handy in the time being as that's the only way to open the trunk without opening the door.
Anybody have a problem like this? and better yet, anybody know what the problem is? Thanks.
Old Aug 24, 2003 | 09:21 AM
Paul89SE's Avatar
i can't open the driver's door if it's locked. I have to open the passenger door or the alarm will go off.
Old Aug 24, 2003 | 10:03 AM
shock211's Avatar
i have the same issue with my trunk.
what i've been advised to do is...check the wiring for the alarm that runs up the driver's side trunk arm and to the alarm solenoid at the lock. if it's damaged...there's why you have the problem. if the wiring appears to be fine. try re-grounding the negative lead to the alarm solenoid for the trunk.
Old Aug 24, 2003 | 10:06 PM
DARHAW-MAX's Avatar
My SE has the same problem and it is related to the Anti-Theft control unit located under the stearing wheel. As I have not troubleshot this subsystem yet, I just disconnected the connector from the control unit. Eveything will still work as normal, but just don't have the whimpy OEM alarm. After I get all of my other small issues knocked out, I will probably replace the control unit with a junk-yard special.
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
Fbana41
Aug 29, 2016 12:18 PM
Redfox
Sep 28, 2015 10:41 AM
