EGT placement
Old Aug 28, 2003 | 11:02 AM
MaDMaX024's Avatar
EGT placement
where should i put my EGT sensor? right before the O2? on one of the downpipes? make an attempt at tapping a manifold? i just want the most accurate reading.
Old Aug 28, 2003 | 11:55 AM
Turbo91max's Avatar
you want it on your excaust. VG or VE? on the VG right before the O2 would be a good spot. and on the VE probably right after the manifold probably.
Old Aug 28, 2003 | 12:14 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
on either car just before the O2 might be too far away ...you shouldn't position an EGT gauge more than 6-8" from the manifold(s). check in the 4th gen forum a few of them have EGTs insatlled...I've only done them on 4cyl. motors...so I'm clueless as to a 6. I'd say the front pipe on the Y and call it a day.
Old Aug 28, 2003 | 12:17 PM
MaDMaX024's Avatar
VE..just after which manifold?
Old Aug 28, 2003 | 12:28 PM
DA-MAX's Avatar
why would the Vg be different than the VE?? that makes no sense
Old Aug 28, 2003 | 12:59 PM
Matt93SE's Avatar
STFU n00b!
I stuck mine about 4-5" down from the flange on the front manifold. easy to get to and out of the way of everything else. (plus when I bolt the turbo in, it'll be in the perfect spot so I don't have to run new wire.)
mpbclutch33
Sep 21, 2015 01:54 PM
ejj
Mar 8, 2002 08:52 PM
bullseye
Mar 5, 2002 07:31 AM
nigelcmf
Feb 25, 2002 07:38 AM
ejj
Jan 11, 2002 08:20 AM
