Brake light rewire
Old Feb 11, 2001 | 06:48 AM
N34JZ's Avatar
Needs non-Maxima Friends
I want to make it so these two light come on as the brake lights right now only the spoiler does.
<img src="http://albums.photopoint.com/j/View?u=1480888&a=11154126&p=40654456">
[Edited by N34JZ on 02-11-2001 at 09:07 AM]
Old Feb 11, 2001 | 08:41 AM
«§»Craig B«§»'s Avatar
first of all, since you have that 3rd brake light on the back deck, you have a GXE with a SE spoiler; you probably already know this, but I just thought I'd make sure
anyway, that should already be wired as a brake light; I guess whomever installed your spoiler disabled that one
if you take it off (I believe two things on the sides) there may be a wiring harness not plugged in and that's all youd have to do. Otherwise, it may have fallen back behind the rear deck or something like that. If you can't find it; you could just run a power wire and ground from the back brake lights to there inside the trunk. If you need the colors for these wires, check some of the other taillight rewire posts because I've posted them within the last week
good luck
Old Feb 11, 2001 | 08:42 AM
also, I forgot to add to check the bulb in the 3rd brake light first; it could be that the bulb is just burned out
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
