cilmate Air
Old Sep 6, 2003 | 07:06 PM
Spazz's Avatar
cilmate Air
I have the digital climite control in my Max and was wondering if when anyone else turns on there front screen demister that only it works and the AC kicks in and making the car colder. Is there a way to modify this or is it broken any help?
cheers Andrew
Old Sep 6, 2003 | 09:12 PM
rcy's Avatar
rcy
When you turn on the front defogger, the A/C kicks in (unless it's below 2 degrees celsius) to help remove the moisture on the windshield. If you find it too cold, just turn up the temperature. The A/C will still dehumidify the air hitting the windshield, but it will be warmer.
Old Sep 8, 2003 | 11:21 PM
Spazz's Avatar
I already found that u just turnned up the heat a bit more. Was wondering if it was wrong because whats the point of having the A/C on if u want warm air, I know that it clears the screen quicker. But if u could have the disister on all the time with out the a/c I wouldn't be so worried.
thanks for the reply
Old Sep 9, 2003 | 05:29 AM
rcy's Avatar
rcy
Can't check this right now (my car is in the shop), but try hitting the defrost button, then the econ button and see if that stops the A/C from kicking in. Econ is supposed to give you heat without A/C, but I'm not sure if the defrost button overrides the A/C or vice versa.
Old Sep 10, 2003 | 10:46 PM
Spazz's Avatar
On mine defrost overrides all other functions. Which is a pain in the @$$. And people think that computerizing cars makes things easier, just more diffacult to modify
Does any one else have any ideas.
C Uooo
Andrew
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
