LSD available with A/T?
Old Sep 12, 2003 | 12:39 PM
internetautomar's Avatar
mod or sell?
Was the limited slip differential also available in the automatics or just on the sticks?
Any body know for sure?
Old Sep 12, 2003 | 12:57 PM
eric93SE's Avatar
92-94 se's with the VE30DE have LSD
Old Sep 12, 2003 | 01:57 PM
mod or sell?
yes! that means I should.
Old Sep 12, 2003 | 02:58 PM
Matt93SE's Avatar
STFU n00b!
not all of them. it was an option, according to the tranny shop that replaced my tranny. you could get the LSD in either auto or 5 spd, but it wasn't standard.
Old Sep 12, 2003 | 03:12 PM
Pit5Bull's Avatar
I know I'm going 2 get flamed for asking this question because I should know better, but what's the advantage of having an LSD? I have an 89SE 5sp, so I doubt that option was available then. Just being nosy
Old Sep 12, 2003 | 03:29 PM
Matt93SE's Avatar
STFU n00b!
nope. it was only available with the VE engine. not even on 4th gens.
Anyway, limited slip is exactly what it sounds like.
notice when you do burnouts on your car that only one tire spins? (not that anybody ever abuses their car by doing a burnout!!!)
limited slip prevents that by making sure torque is applied to both wheels through a viscous coupling (sticking molasses between the axles in layman's terms.)
benefits are all over the place. no one-legged burnouts at the drag strip or when trying to accelerate on set roads, and accelerating out of a corner. if you auto X or track the car, you'll notice the inside wheel always spins coming off hard corners. the LSD will help stop that- not completely, as I still spin in 1st and 2nd gear, but it helps.
do a bit of searching online for limited slip or viscous limited slip (the type on the Max) for a better definition.
Old Sep 12, 2003 | 05:30 PM
Mizeree_X's Avatar
Getting back to his roots
I have a bit of nostalgia that may contradict that statement (at least for the 5-speeds).
Notice the last item in the "standard equipment" section.
Old Sep 12, 2003 | 05:31 PM
Pit5Bull's Avatar
@ Matt93SE ---> U da man, bro!!! Thanks for the explanation. Now that I know what it is, it's not going 2 do me any good since they don't make them for 3rd Gen's anyway
Old Sep 12, 2003 | 05:36 PM
Gjohnson's Avatar
They do make it for the 3rd gen, but only 92-94 SE models.
Old Sep 12, 2003 | 05:44 PM
LittlePiggie's Avatar
how come my 91se spins both wheels then? EVERY roast I've done has spun both tires...
Old Sep 12, 2003 | 05:54 PM
DARHAW-MAX's Avatar
Look on the metalic plate on the firewall.
RE4F04A = NON LSD
RE4F04AV = LSD
Mizeree_X--
Nice post. I have to save that picture!
Old Sep 13, 2003 | 02:35 AM
Spazz's Avatar
4th gens have lsd's I'm sure well they do in New Zealand any ways.
Old Sep 13, 2003 | 06:59 AM
Matt93SE's Avatar
STFU n00b!
the US spec 4th gens don't have them, no. they're now available via aftermarket after several years though.
Mixiree, when I purchased my VE, it didn't have LSD in it. after I blew it up and installed a new tranny, I installed one with LSD. but you can get them with or without it even from the factory.
Pit5bull, there have been LSD swaps done into VGs. I know a couple people tho have done them. the VE tranny will bolt right up. you just have to swap axles, hubs, carrier bearing support, and a few other things.
Old Sep 13, 2003 | 09:57 AM
Maximan190's Avatar
my auto had it, and my 5sp also does
ef9
Aug 14, 2015 03:03 PM
Supragte
Aug 12, 2015 10:00 PM
09maxshawn11
Aug 9, 2015 01:13 PM
LoveSick
58
Jul 23, 2001 01:36 PM
Omegasrk
Nov 8, 2000 03:34 PM
