blown fuel pump fuse
Old Sep 16, 2003 | 11:50 AM
5spdMaximaSE's Avatar
This morning I was driving and when I was returning home I noticed that all my dash lights were on and my car off as I approached a stop light. I was like wtf...and tryed turning on the car, and it wouldnt start. I put on my hazards and started checking things..I figured it may be the fuel pump since the car wouldnt start up. I checked the fuse, it was blown so i changed it and turned on the car. Car shuts off almost immediately and i check the fuse is blown again. I tryed it one more time and it blew again. At this point I was gonna get it towed..like 10 min later I try another time with another fuse and the car started and ran just fine. I bought more fuses and drove around some more, no problems yet. What might have gone wrong?
Old Sep 23, 2003 | 07:33 PM
bullseye59's Avatar
I am having the same problem...does ANYone know what would cause this that has it happen to them in the past???
Old Sep 23, 2003 | 09:49 PM
well its been a week with no problems like that, so hopefully it wont happen again....maybe some wiring was wet because it rained a day before that happened???
Old Sep 24, 2003 | 06:33 AM
subs1000w's Avatar
i could have somthing to do with your fuel pump getting to old and hot and not wanting to turn on but i dont know thats really wierd if it happens again i would just replace the fuel pump its only like 100$ then go from there
Old Sep 24, 2003 | 05:49 PM
eric93SE's Avatar
Could be the fuel pump relay (its in the truck). Even though its hard for me to figure out why yours could cause such trouble, they are known to go bad. Let us know if this is the case.
Old Oct 4, 2003 | 07:26 AM
deaconhdwy's Avatar
Bros. I had the same problem. After investigation it turns out the wiring was not grounded properly and was causing a short. My dilemma was I already purchased a fuel pump and ended blowing out the pump again. Check the wiring and make sure that's not the source of the short.
Old Oct 4, 2003 | 07:31 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i agree check the wiring first before you start replacing parts.
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
