Engine Missing
Old Sep 23, 2003 | 06:22 PM
mjwitte99's Avatar
Engine Missing
Looking at my engine from the front the back left cylinder is missing. I have checked the ignition coils, spark plus, and fuel filter. Does anyone have an idea of what to check next. Thanks a million for anything.
Old Sep 23, 2003 | 06:39 PM
internetautomar's Avatar
mod or sell?
Injector!
Common problem on maxima though moreso on the VG than the VE. Check the resistance on the injector as compared to all of the others. They should all be within 5 ohms of each other (If I remeber correctly)
Old Sep 23, 2003 | 08:02 PM
broncoguy's Avatar
spec is 10-14 ohms...
Old Sep 23, 2003 | 08:06 PM
mod or sell?
Thought it was something like that. Just couldn't remember. BTW that spec is for when the injectors are at 70 degrees Farenheit.
Old Sep 23, 2003 | 08:15 PM
subs1000w's Avatar
i didnt think it mattered how hot they are but mine alway read the same engine hot or cold
Old Sep 23, 2003 | 08:21 PM
mod or sell?
Just relaying the info I recall being told by a rebuilder
Old Sep 24, 2003 | 07:21 AM
mjwitte99's Avatar
Is this a difficult job to do? I have decent mechanical skills, but dont really want to get in over my head. If it is an easy job what all do i need to complete this.
THANKS
Old Sep 24, 2003 | 07:32 AM
mod or sell?
Yes, you can do this yourself. Just be sure to gather togrther all the parts before starting the job. and if possible have second car there in case you break a bolt or need some other odd part that you forgot.
I just had 3 of mine done 3 weeks ago. Remans work great.
Just my .02
Old Sep 24, 2003 | 10:40 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
hope mine dont go. i have enough to do. think i nay try rebuilding the vtc's buying seems to be getting too expensive.
Old Sep 24, 2003 | 09:53 PM
bvtran's Avatar
94c Big Max
if all of the above still didn't answered your questions, then check your spark plugs gap. Depending on what you got, most standard plugs get around 0.044" while plantinum and iridium could go to a much smaller gap. You probably didn't get enough fire powers that's all.
Old Sep 25, 2003 | 06:46 AM
mod or sell?
WHY would you go to a smaller gap?
and according to NGK they are all to be gapped at .044 regardless of year or motor in your max
OK that excludes the diesels
Old Sep 25, 2003 | 06:59 AM
tmuscedere's Avatar
Check your injectors, common problem. Resistance should be between 0.8 and 1.2 ohms. Took me about 2 hours to change all six of them. Only was going to do it once.
conansriver
Nov 18, 2015 02:46 PM
dcam0326
Sep 18, 2015 04:52 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
A32goldylocks
Sep 2, 2015 06:39 AM
